Spikes for my Polk Subs
Devlon
Devlon Posts: 355
I broke off one of the rubber feet on one my Micropros somehow and I decided to try spikes. Problem was that all the spikes I researched needed for you to do some drilling of larger holes in your sub for the socket part of the spike to fit Too much of a hassle. I called Polk and they said the threads on their sub feet was 3/8". I saw these on Parts Express, ordered them, and they work perfectly in the sockets already in the sub. At first, I though they didn't look cool enough but after I installed them on my subs you can't see them anyway. They work perfect! Just thought I pass this on. I assume they'll work with any sub posts or spikes that are 3/8"
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-725
Living Room: HK AVR 354 as pre/pro, 2 x Polk Audio Micropro 4000, Adcom GFA-7500, 2 x Mirage OMD-15
2 x Mirage OMD-5, 1 x Mirage OMD-C1, APC H15, Sony S790, Philips 52" LCD, Beogram 3000, FAT (Firestone Audio Tobby DAC), Harmony One
Den: Sherwood R-972,as pre/pro, 2 x Velodyne SPL-1000R, 3 x Crown Drivecore XLS1500, 2 x Polk Audio Lsi9
1 x Polk Audio Lsic, 2 x Polk Audio Lsifx, Sony S790, APC H15, Dspeaker Dual Core 2.0, W4S DAC 2, Keces DA-151
Post edited by Devlon on
  • thsmith
    thsmith Posts: 6,082
    edited May 2013
    Thanks for sharing.
  • amgala
    amgala Posts: 111
    edited May 2013
    Have the spikes changed the sound/performance of your sub?
    Front Speakers: Polk Audio LSi15 x 2
    Center Speaker: Polk Audio LSiC
    Rear Speakers: Polk Audio LSiF/X x 2
    Subwoofers: Polk Audio PSW505 x 2
    AVR: Denon AVR-3313CI
    Amp: Emotiva XPA-5
    F1nut Posts: 52,164
    edited May 2013
    The DSW Pro subs use 6mm threads.
  • Devlon
    Devlon Posts: 355
    edited May 2013
    amgala wrote: »
    ecause
    It's hard to say, because I got the Sherwood R-972 (Trinnov mode) almost the same day the spikes came in, and when I ran Trinnov the subs changed so dramatically that I don't know how much could be attributed to the spikes. I do know that the subs don't move anymore like they would sometimes do on movies like U-571.
  • amgala
    amgala Posts: 111
    edited May 2013
    Gotcha. Glad to hear you are enjoying your system more!
    Amp: Emotiva XPA-5
  • Spiffyfast
    Spiffyfast Posts: 35
    edited May 2013
    Never thought about spiking a sub, interesting
    Mains: Polk Audio SDA-2Bs
    Center and Surrounds: Bic Acoustech
    AVR: Pioneer 1015tx
    Amp: Anthem Amp 1
    Turntable: Project Debut III
    Inputs: Xbox 360, Samsung BDP-1000, Apple TV
  • zane77
    zane77 Posts: 1,696
    edited May 2013
    Spike your subs! I put spikes on my 505's and couldn't believe the difference.
    Two Channel
  • custopper30
    custopper30 Posts: 252
    edited May 2013
    How did the difference change??
    Receiver: Denon 1912
    Speakers:
    Fronts: Polk Audio Monitor 70s (x2)
    Rears: Polk Audio Monitor 50 (x2)
    Center: Polk Audio Monitor 70
    KLH Sub GFX-550
