Cable mount connectors anyone?
Spring cleaning............
8- Vampire gold plated 3 pin XLR connectors......$35/shipped for all 8 (4Male-4Female).
40- Audioquest BNC plugs (ITC24)............$25/shipped for quanity 20! (Box) or $3/ea. shipped!
I have additional gold plated rca plug adapter inserts for very little extra cost.
40- 1/8" MCM female stereo plugs (brand new still sealed), very nice, the positive solder stud is pure copper....$2/ea shipped (best I have EVER heard for 1/8" to dual rca plugs)!
ALL ARE BRAND NEW NEVER USED!
Paypal only, no fee, Lower 48 states only.....
  • starkiller
    starkiller Posts: 2,723
    edited May 2013
    Excuse my ignorance but the BNC connectors convert rca cables to BNC ones then?
    Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
  • Systems
    Systems Posts: 14,872
    edited May 2013
    Yes, the BNC's would then be rca plugs (Like the BlackCat digital cable) I have some very good adapters (better than most on the market) that I would let go for super cheap if you buy the BNC's.
    That said, the Audioquest BNC's are non-solder types.
    You simply buy the cable off Ebay for example and strip the wire, and it is as simple as plugging the stipped wire into the ITC-24 BNC plugs, then you get a TRUE 75 Ohm impedance, especially important with digital cables!
    Great wire, great plugs, win/win formula!:cheesygrin:
    Several types of Audioquest wire can be used.
    Testing
    Testing
    Testing
  • Systems
    edited May 2013
    Not to mention Alan, with the rca adapters, they would make EXCELLENT analog rca cables!:cheesygrin:
    If I had room in my main components (internally), I would go ALL BNC connectors throughout.
    Both analog and digital.
    Prolly the best connection type on the market today (bar none:cheesygrin:), I've made a "few" solder types in the past!:lol:
    Testing
    Testing
    Testing
  • starkiller
    edited May 2013
    Ok, here is what i need..besides a new brain :sigh:, have a DAC where the digital out rca is bad, so the manuf is sending a BNC cable for me to use. BNC at one end and RCA on the other. Would prefer to use my nice RCA cables instead of his cheap china one so need to attach to the BNC connection on the unit...savvy??:wink::mrgreen:
  • Systems
    edited May 2013
    I didn't realise you had good digital cables Alan?:lol::lol:
    No, most BNC chassis mounts are female plugs.
    Most cables are male.
    We may be able to figure something out if you want to pm with a more detailed description?:cheesygrin:
    Testing
    Testing
    Testing
  • starkiller
    edited May 2013
    Sigh +2..so this means no go then...as you can tell i be confused..understand the male/female thing ( I better) but just want to use my decent rca digi cable instead of the cheap china one...
  • Systems
    edited May 2013
    If you have an rca input on the source, yes you can use one of these adapters.
    If it is BNC on the source, no you cannot.
    Just pm, not 100% what the hell you are talking about to be sure!:eek:
    Testing
    Testing
    Testing
  • starkiller
    edited May 2013
    sigh + 100..you have a pm
  • Systems
    edited May 2013
    Ummmmm............... Pretty sure I can take care of any "input problems" you may have Alan!:lol:
    I ate a DAC chassis earlier with a nice salad (I prefer Ranch Dressing).
    Doubt you have a problem that has not been discussed on this forum, or that I have not done previously!
    PM sent!
    PS: I have some nice test equipment!:cheesygrin:
    Testing
    Testing
    Testing
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited May 2013
    I'll take the Vampire Wire XLR's. Sending PM
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • Systems
    edited May 2013
    XLR's are sold!
    Sendiing pm Doug!
    Testing
    Testing
    Testing
    EndersShadow Posts: 17,715
    edited May 2013
    Pep, PM me your phone number, I have some questions on the BNC connectors, specifically related to making RCA IC's with them....
  • Systems
    edited May 2013
    starkiller wrote: »
    Send it to me Alan, I'll fix it.
    No charge except for shipping costs and any parts costs.
    Keep in mind, I may need to give it a good long "listen" before sending it back!:lol:
    JK!
    PS: I have one of the AudioNote silver rca inputs we discussed on hand here, it is used however, but should work great for this application, or the Cardas rca input link I sent ya.
    Testing
    Testing
    Testing
  • Systems
    edited May 2013
    Yeah right, like I am going to give you the opportunity to make fun of my Arkansas accent!
    Pleeeeeaze!:rolleyes:
    Analog IC's using the Audioquest BNC's (TRUE 75 ohm connection especially important for digital!:cheesygrin:) but excellent for analog also:
    Testing
    Testing
    Testing
