Harmony One IR Signal
zingo
I was trying to program my Harmony One remote tonight to control the volume of my preamp which is not in their system. I set-up the device, program it by feeding the IR from the original remote, then set the commands and tried it out. On the original remote, when I push up or down volume, it goes up one click. When I push up volume on the One, it goes up 15 clicks, and when I push down volume, it goes down 5.
After going to the help menu in the Harmony software, I did change the repeats from 3 to 0, but that didn't make a difference.
Any suggestions? I bought the Harmony One so I wouldn't have to swing two remotes, but I haven't been able to solve this one yet.
Thanks for the suggestions!
Post edited by zingo on
Bump
Might be worth a call to them or post on their forum (I think they have one)...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Thanks for the suggestion, and I posted the question on their forum. I got one response which was to have the remote relearn the IR signal, as it learns the signal as an exact copy, and I possibly held the button down too long or something similar. I was having an issue with the Harmony seeing the preamp remote signal, so I'll give it a try again with very short IR blasts.
I believe your problem is timing, the dead space between signals. Look for something called timing in the harmony on the web based setup, try increasing the timing.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
