Harmony One IR Signal
zingo
zingo Posts: 11,258
edited May 2013 in Electronics
I was trying to program my Harmony One remote tonight to control the volume of my preamp which is not in their system. I set-up the device, program it by feeding the IR from the original remote, then set the commands and tried it out. On the original remote, when I push up or down volume, it goes up one click. When I push up volume on the One, it goes up 15 clicks, and when I push down volume, it goes down 5.
After going to the help menu in the Harmony software, I did change the repeats from 3 to 0, but that didn't make a difference.
Any suggestions? I bought the Harmony One so I wouldn't have to swing two remotes, but I haven't been able to solve this one yet.
Thanks for the suggestions!
Post edited by zingo on
  • zingo
    zingo Posts: 11,258
    edited May 2013
    EndersShadow Posts: 17,750
    edited May 2013
    zingo wrote: »
    Bump
    Might be worth a call to them or post on their forum (I think they have one)....
  • zingo
    zingo Posts: 11,258
    edited May 2013
    Thanks for the suggestion, and I posted the question on their forum. I got one response which was to have the remote relearn the IR signal, as it learns the signal as an exact copy, and I possibly held the button down too long or something similar. I was having an issue with the Harmony seeing the preamp remote signal, so I'll give it a try again with very short IR blasts.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2013
    I believe your problem is timing, the dead space between signals. Look for something called timing in the harmony on the web based setup, try increasing the timing.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
