Amp buying help
Mtnpolk
So my set up is this:
Fronts- RTIa7`s
Center RTI a 4
Rears/surrounds- Klipsch Synergy SL
Sub- Velodyne 3750
TV- JVC 47"
AVR- Pio Elite VSX-01
Now, I have about 300 hours on the 7`s and love them for movies. I can definitely hear/see why a power amp could open them up for music. I have never ventured into seperates, so I need help with the whole amp thing.
Here`s what I think I know:
My AVR has pre-outs for all channels and claims 110wpc in stereo 220 w total. I think I only need/want to amp the front two as I only listen to music in stereo. I KNOW that I do not have sufficient funds to get what is ideal.
Here are my questions- what is the minimum power rating that I should be looking for? Does the amp add to the AVR`s power for that channel, or is it fully powering those two channels? Any chance I can get into a used item for a couple hundred bucks? Can an amp designed for a rack be used w/o one on a shelf? Does anyone have one they want to donate;), sell or barter that would allow me to dip a toe in the seperates water w/o going broke?
Fronts- RTIa7`s
Center RTI a 4
Sub- Velodyne 3750
TV- JVC 47"
Post edited by Mtnpolk on
No, an amp does not add to a receivers power. A couple hundies.... look at Adcom or Carver on your local craigslist, here in our FM.HT SYSTEM-
lsi 9's -
Assuming your looking at solid state, and not tubes, you want 200 watts or more for your amp. You could probably get away with a little less, but may as well get one that will cover just about anything.
The vast majority of rack mountable amps can be set on a shelf, I'm sure there is an exception or 2.
If I were you, I would plan on spending at least $500 on a decent 2 channel amp. Lets face it, an amp will probably out last all of your other present gear, so lets not go really cheap here,
When you plug an amp into the pre-outs, you are telling your AVR that is now just a pre-amp for those channels. It will output no power to those channels, so you will rely solely on the amp. Again not good to scrimp here, especially if you really like those A7's. -
So, in reading a bunch of posts here, I think that i can afford a Crown XLS1000, maybe the 1500. Is that,. technically speaking, a decent choice? Not really worried so much about intrinsic likes/dislikes, just want to see if I am on the right track.
Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
With the RTi A series you want a warmer sounding amp as the speakers are on the brighter side. I'd suggest something from Parasound or B&K.Political Correctness'.........defined
President of Club Polk -
i just got a B&K Ref 2220 and I am enjoying it quite a bit so far. I also have an HCA 1200 MkII which will most likely be needing a new home soon.Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
The 1500 has a lower noise floor than the 1000. It's S/N is is better by 6dB and you will see it recommended over the 1000. -
The Crown amps have mixed reviews..there are questions about the quality and the fans. Might be fine for some or a problem for others. IMO, I would not use a pro amp like than unless I had my gear in a closet. Maybe consider used gear if your budget is tight? Something like a used Adcom GFA-5800 for some serious boost or a supposed warm amp like B&K. There are tons for sale around on the net and craigslist.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3 -
I second CL. I picked up a NAD receiver for $75 & an Adcom with a preamp for $100. You need to be patient tho. If you're in a hurry, its not for you.
?? The XLS have no fan noise from all reports. Crown is also known for reliability over the years with only a few problems. -
OK... As I am new to the whole Amp thing myself I just looking for a little more clarification. From what I read above, I am understanding that the receiver either pre-amped or passing through an separate pre-amp to an amp does not add the receivers power to the total power.
Example:- 100wpc receiver, passing through a pre-amp through a 100wpc amp is still only producing 100wpc? If so, I essentially need a 200wpc amp in order to obtain 200wpc.Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Elemental Designs A2-300 Subwoofer
Panamax M4300-PM Power Conditioner
Working on updating my set up :rolleyes: -
Whatever the amp is is what you'll get.. yes if you want 200 watts you'll need a 200watt per channel amplifier. That's 200 watts for 8 ohms as your speakers are 8 ohms.
Basicly a Emotiva XPA-2 is a 2 channel 300watt per channel amplifer.. then theres mono amps that could give you 500 watts for a single speaker in the Emotiva XPA-1 amp and you would need 2 of them for stereo.. though there new XPA-1L looks good at 250 watts but you'll need 2 of them.
Your A9s will take up to 500 watts each but you don't have to have a 500 watt amp to run them as you can get away with 200 watts most likely though 500 watt amp will use them to there potential. Its not all about watts for high volume its about clear great sound at lower volume as well.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
Eclypse- Thank you for assisting in the clarification.Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
I recommend you to buy the noise level of upper one thousand.
