Rti6 vs Rti-A3... any difference?
I currently own a pair of Rti 6s and love them but the shape and style of the A3s are calling me. Anyone have any experience listening to both? Other than the cabinetry, is there any significant difference to the drivers, x-overs, etc or is it purely cosmetic? Thanks!
Life's too short too listen to bad speakers
Post edited by jmitchnh on
V3R says the crossovers are different between the RTi's and A's. The A's are supose to be a little less bright from what I have been told.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Well the two best ways to find out are 1. Listen to both and if that isn't possible then read stereophiles review of both focusing on the measurements. If I recall correctly they both have similar high frequency bumps that produce that bright sound that people refer to. I prefer the rt25i myself.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
The majority of the changes are actually in the midbass and bass circuits. Fwiw- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Hmmmmmmmm. Any way to get a look at the crossover schematics of the two? I'm curious to see what they may have changed :question:Life's too short too listen to bad speakers
What are you pairing them with? Is this your main speakers with a sub?
I heard but cannot confirm that the RTi6 can be used with stands pretty easily but you will have to make some mods for the A3's.Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Elemental Designs A2-300 Subwoofer
Panamax M4300-PM Power Conditioner
Working on updating my set up :rolleyes:
