Should I pre-wre for 5.1
sid369
sid369 Posts: 34
Hi all,
I have an option to get a 5.1 pre-wired by my builders vendor. However, I am not sure of the location and feel that it will force us to lay our furniture around it.
This is for the family room on the first floor, there is unfinished basement. Should I do it now or can this be done later.
I am sure it will be cheaper to do it now vs. later. What do you guys suggest. The yellow highlight is where i have marked as the location initially.
here is the layout
Post edited by sid369 on
  • monepolk
    monepolk Posts: 1,154
    edited May 2013
    If it were me I would do it now. Even if you decide to change things around, look at it like an outlet that you're not currently using.
  • sid369
    sid369 Posts: 34
    edited May 2013
    monepolk wrote: »
    Do you think my marking are a good location
  • amgala
    amgala Posts: 111
    edited May 2013
    I think I would put the rear channels in the corners like the front channels. That way, even if you change the furniture layout, you would get similar sound.
    Also, having the subwoofer in the corner may cause unwanted vibrations (particularly with a window right there) and boominess from the sub. I would thing it would be better to put the subwoofer closer to the sofa.
    Front Speakers: Polk Audio LSi15 x 2
    Center Speaker: Polk Audio LSiC
    Rear Speakers: Polk Audio LSiF/X x 2
    Subwoofers: Polk Audio PSW505 x 2
    AVR: Denon AVR-3313CI
    Amp: Emotiva XPA-5
  • amgala
    amgala Posts: 111
    edited May 2013
    Sorry, I thought you were thinking about getting ceiling speakers, but I just saw your other thread so now I know you are going to get towers.
    I would definitely have them wire it for 5.1 from the get go, and my comments about the subwoofer still hold true.
    Amp: Emotiva XPA-5
  • monepolk
    edited May 2013
    I'll let someone else answer that. I think corner placement of your connections give you the most flexability as far as changing things around.
  • David R
    David R Posts: 134
    edited May 2013
    I just post wired my place for 5.1 sound. It is very expensive to do it afterwards. I had to go through an existing finished ceiling. You can put in extra wire to allow you to change your configuration later. Much better to do it now.
    Panasonic 65" Plasma - Panasonic Blu-ray. Onkyo TX-NR809 RTi A7s fronts - MK CS150s surronds.
    edited May 2013
    Also, if your going to pre-wire, use good quality wire from the get-go along with quality connectors. The contractor will use the cheapest available. Pick your own and have him do it.
  • classic carl
    classic carl Posts: 662
    edited May 2013
    I would place your mains closer together and move the surrounds further apart. I would also put the sub on the front wall and not in a corner.
    I wired my rear surrounds myself before the drywall was installed, while my houise was being built, as opposed to paying someone to do it. I would not hide the wire for the fronts or sub in the wall.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • sid369
    sid369 Posts: 34
    edited May 2013
    Let' say I have the pre-wiring done and its in the corners like in the layout. Wouldn't I still be able to move the speakers closer to the tv or further away from the corner walls. The wires from the wall outlet connected to the speaker will show but I will still be able to move the speakers, am I correct?
    Because there will be wire from the speaker connecting to the wall outlets.
    The reason for the sub in the corner wall placement in the back was because if I want the sub in the front, I can directly connect it to the receiver, and that way I have two locations, one pre-wired and the other direct to the receiver.
    Am I thinking this correctly? I don't think the builder will let me put my own wires, and even if they did I won't know what I will be doing as I have no idea.
    I think the guy told me that they would use 16 gauge wires, so my question is from the outlet to the speaker, does it have to be the same wires? or can it be different gauge?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2013
    I would insist that they let you choose the wire they use. I would talk to a custom installer in your area and bring them in as a consultant, the builder is going to use the absolute cheapest stuff possible...
    txcoastal1 Posts: 13,518
    edited May 2013
    Where will the head end be located?
    If it is where your TV is located then using good quality cables to your receiver won't be a problem if you don't mind them exposed.
  • samreddevilz
    samreddevilz Posts: 18
    edited May 2013
    You may do this. But be careful about your setup currently.....//
  • sid369
    sid369 Posts: 34
    edited May 2013
    What do you mean?
    All the gear - Receiver, STB etc. will be where the TV is
    edited May 2013
    If the builder leaves you with no other option the 16awg to the rears will be fine. Since equipment will be at your TV stand then you can always use better quality cables for the Fronts and center, they just won't be in the walls.
    I would prefer 12awg for the fronts and 14awg for the rears...just my .02c
  • Spiffyfast
    Spiffyfast Posts: 35
    edited May 2013
    Good suggestions on picking the wire yourself if they'll allow it, good luck
    Mains: Polk Audio SDA-2Bs
    Center and Surrounds: Bic Acoustech
    AVR: Pioneer 1015tx
    Amp: Anthem Amp 1
    Turntable: Project Debut III
    Inputs: Xbox 360, Samsung BDP-1000, Apple TV
  • philr168
    philr168 Posts: 91
    edited May 2013
    I pre-wired my home when building it. It saved a lot of time and expense by not having to hide wires later. Run as heavy of gauge as possible now and save regrets later.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited May 2013
    As a former alarm and telco,cable,music installer it is way better to pre-wire before the walls go up.Just make sure whom ever does it follows after the electricians and knows somewhat about code in your state ie. nail plates,boxes,mud rings.Yes you can do it later but there is alot more time and mess involved .Just lay it out and mark where you want to terminate and any one should follow your directions. One other thing make sure you where your cable box will be that can determine a few more wire runs like HDMI,Optical.
