2.0 amp with four speakers and a sub
pnewelljr
Is there any chance I would be able to use all of this together? Or is the amp not powerful enough?
NuVo Wa40
http://www.nuvotechnologies.com/wa40
4 x Polk Audio 700-LS
http://store.audioholics.com/polk-audio-700-ls.html
Earthquake Sound CP8 Sub
http://www.amazon.com/Earthquake-Sound-CP8-Subwoofer-Laminate/dp/B005W8NEXA/ref=sr_1_1?ie=UTF8&qid=1367987528&sr=8-1&keywords=Earthquake+Sound+CP8+Couch+Potato
Thanks!
NuVo Wa40
Thanks!
Post edited by pnewelljr on
I don't think that amp is really designed for home audio use; I can't really tell from the link how it's designed to be used other than by kids raising their hands...
What about a standard multi-channel receiver to drive the speakers, and it would already have a subwoofer out? -
NuVo Wa40
Thanks!
It seems like you should consult a professional A/V installer who would have the expertise and access to the right equipment to install a whole house/in-wall music setup. Are you up to the task of cutting holes in drywall, fishing cables, and refinishing the walls ?Main System: Denon DP-59L | Audio-Technica AT33EV | Marantz SA-11S2 | Classe DR-10 | Classe CA-300 | Classe RC-1 | PSB Stratus Gold i's | DIY Balanced AC Power Conditioner | Acoustic Zen and NeoTech cables | Oyaide and Furutech power connectors | Dedicated 20A isolated ground line.
