Balance and unbalanced at the same time?
hochpt21
I'm sure this is a quick answer, but I couldn't find anything on my own searching.
My amp has balanced and unbalanced inputs along with a 'toggle' button to switch between.
Question is...am I able to hook both the balanced and unbalanced connections and toggle between depending on what gear I am using?
Here is what I am looking to do...
My phono pre has multiple gain controls and can operate hooked directly into an amp. So I would like to hook the phono pre to the balanced inputs on my amp; then hook the Parasound to the unbalanced.
Will this work?? (i don't want to damage any gear by trying this on my own first)
Thanks,
Paul
Thanks,
Paul
Post edited by hochpt21 on
I saw a post similar to this recently and the poster was using two preamps, I believe, and he said to make sure that the unused preamp was switched off before switching to the other inputs. Sorry I can't remember the thread I read about this in. I think you could do this if you switched off the preamp between changing the inputs on your amp.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
I think you're fine if you are using the switch input.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
As long as the switch disconnects the unselected input, you shouldn't have a problem; summing the voltage on both inputs would cause a problem with your amp. I personally would prefer to switch through a preamp, but I respect your goal of minimum components in the audio chain!
Thanks for the replies.
It sounds like as long as the pre-amps are powered off while I push the switch on the amp, and the un-used pre is kept off during the other one's operation...I should be fine.
Any other opinions?2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Ok...switched some stuff around today.
The GCPH is now connected directly into the balanced inputs on the 200.2. Noticeable upgrade in SQ to my ears. When I got the GCPH from a forum member this is how he recommended it hooked up. He was right.
The Oppo and the Duet are hooked up to the DLIII, then unbalanced to the direct one input on the P3. The P3 is hooked to the unbalanced inputs on the 200.2.
After making sure all components are off between each 'switch' and then only turning on the correct gear...the 200.2 will work with both unbalanced and balanced connections.
It will be a little inconvenient to switch the toggle on the back of the amp each time, but worth it IMO so far for the increased SQ in my vinyl rig.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
