Sda srs2.3tl
bikezappa
I know this question has been asked before but I can't find the correct information.
Problem is the right speaker midrange and tweeters cut in and out at low volume. I think it's the poly switch.
Two questions
1. How to I get at it? Take out the woofer?
2. Can some one show me a photo of the poly switch in the cross over board?
Much thanks
Peter
Two questions
Much thanks
Peter
Post edited by bikezappa on
poly switch would not effect the mids it is only tweeter protection something else would be going on. On your boards look for a little blue square thing or little brown circular thing. little like 1/4 to 7/16" of an inch very small.
They are broke and can't be fix, I will give you $100 for them as is..
I up bidding to $101.
One thing to check would be swap that driver with the other speaker and see if the problem follows.
Peter, remove the passive radiator to gain access to the crossover board. It may seem like you've lost the mids, but pitdogg2 is right, the poly is only in the high frequency circuit.Political Correctness'.........defined
President of Club Polk -
Sounds like a good excuse to redo the crossovers.
I had a Carver TFM-15 that did that on one channel.
All you next to do is swap channels to test the amp and the speakersPOLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
What amp are you driving them with? Could one channel be clipping and causing this?Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Legacy Audio Focus SE
Legacy Audio Silverscreen HD center
Polk F/X500i Rears
Parasound HCA-3500
Sunfire Grand Cinema
Behringer iNUKE NU6000DSP
Pair of CraigSUB SS-18.1 -
F1nut Thanks. I think I thought lost the mids and tweets but I maybe wrong.
I have a Revox amp and the sound goes away on the right channel only at low or high volume. I have switched the right speaker and the sound stays on.
I have spare poly switches. Some where?
Does anyone have a photo of the poly switch on the crossover?
Does anyone sell redone crossovers here?
Thanks for all your help. -
Thanks Pitdogg, great information.
thanks i had similar issue's w/ my brother's. great info
