Sda srs2.3tl
bikezappa
bikezappa Posts: 2,463
edited May 2013 in Vintage Speakers
I know this question has been asked before but I can't find the correct information.
Problem is the right speaker midrange and tweeters cut in and out at low volume. I think it's the poly switch.
Two questions
1. How to I get at it? Take out the woofer?
2. Can some one show me a photo of the poly switch in the cross over board?
Much thanks
Peter
Post edited by bikezappa on
    pitdogg2 Posts: 25,685
    edited May 2013
    poly switch would not effect the mids it is only tweeter protection something else would be going on. On your boards look for a little blue square thing or little brown circular thing. little like 1/4 to 7/16" of an inch very small.
    Toolfan66 Posts: 17,333
    edited May 2013
    They are broke and can't be fix, I will give you $100 for them as is..:lol:
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • Mystery
    Mystery Posts: 2,546
    edited May 2013
    I up bidding to $101. :lol:
    One thing to check would be swap that driver with the other speaker and see if the problem follows.
    F1nut Posts: 50,753
    edited May 2013
    Peter, remove the passive radiator to gain access to the crossover board. It may seem like you've lost the mids, but pitdogg2 is right, the poly is only in the high frequency circuit.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited May 2013
    Sounds like a good excuse to redo the crossovers.
    I had a Carver TFM-15 that did that on one channel.
    All you next to do is swap channels to test the amp and the speakers
  • Phasewolf
    Phasewolf Posts: 514
    edited May 2013
    What amp are you driving them with? Could one channel be clipping and causing this?
    Absolute corruption empowers absolutely.
    Lg 55LW5600 TV
    Onkyo PR-SC 5508
    Legacy Audio Focus SE
    Legacy Audio Silverscreen HD center
    Polk F/X500i Rears
    Parasound HCA-3500
    Sunfire Grand Cinema
    Behringer iNUKE NU6000DSP
    Pair of CraigSUB SS-18.1
  • bikezappa
    edited May 2013
    F1nut Thanks. I think I thought lost the mids and tweets but I maybe wrong.
    I have a Revox amp and the sound goes away on the right channel only at low or high volume. I have switched the right speaker and the sound stays on.
    I have spare poly switches. Some where?
    Does anyone have a photo of the poly switch on the crossover?
    Does anyone sell redone crossovers here?
    Thanks for all your help.
  • bikezappa
    edited May 2013
    Thanks Pitdogg, great information.
  • locnguyen26
    locnguyen26 Posts: 34
    edited May 2013
    thanks i had similar issue's w/ my brother's. great info
