Replacing Speaker Cone - Tools Needed?
Chris in Philly
Chris in Philly Posts: 2
edited May 2013 in Troubleshooting
I am going to be replacing a damaged mid-range cone in my RTi A9.
The heads on the bolts holding the units in do not seem to be Hex wrench compatible,
as I thought.
How do I remove the bolts?
And will I need other tools to complete the job? (other than normal screwdrivers and such).
Post edited by Chris in Philly on
    pitdogg2 Posts: 27,228
    edited May 2013
    as I thought.
    should be 9/32 hex/allen key/wrench
  • Chris in Philly
    edited May 2013
    Actually, it needed a Star T20 head to turn the bolts.
    (9/32 is way too big; it looked like a much smaller hex, at first glance.)
    The bolts came out easily, the units were easily unfastened from the clips on the wires.
    I had to line up the surround with the unit (not a big deal, some balancing involved).
    The new mid-range is in , and sounding fine.
    edited May 2013
    My bad it was off the top of my head... turns out that is the drill bit size I used on another project:rolleyes:
    I did not know that they used torx head stuff. Most i have seen was small allen key.
    Glad you got it.
