New Flexy is in da'house
Ron-P
Ron-P Posts: 8,520
I finally got my DVDs moved into the closet, ditched the A/V cabinet and makeshift TV stand. I am just about done with the flexy below, little more touch up to do.
Little hard to see the equipment. Top right is the Marantz SR5000, below that is the Monster HTS2500, to the left is the JVC progressive player with a Sony VCR under it. Then of course the cigar box in the bottom left, next to wilson.
Next, update the Green Room website. Hopefully get those done this weekend.
Peace Out~:D
If...
Ron loves a film = don't even rent.
  • CHRIS
    CHRIS Posts: 454
    edited March 2002
    Looks real good man. BTW Wilson looks a little to clean.
    Chris :)
  • juice21
    juice21 Posts: 1,866
    edited March 2002
    looks good ron! so, when will mine be done?:D
  • SPEAKER7
    SPEAKER7 Posts: 355
    edited March 2002
    Ron,
    I guess Moulin Rouge is still one of your favorite DVD's.......I notice it sitting on top of your equipment! Anyways, don't work too hard moving everything around and hope to check your new updated website once it's completed.
    dc.
  • Aaron
    Aaron Posts: 1,853
    edited March 2002
    Are those 3/4" rods? They look pretty beefy.
    Aaron
  • Ron-P
    Ron-P Posts: 8,520
    edited March 2002
    Yep, just watched it last night after I got everything hooked back up.
    Yes they are. I have them covered with that plastic split tubing stuff you wrap up cables in. Works great and I do not need to paint the rods.
    Haven't decided it I am going to paint the nuts and washers or just leave them.
    Peace Out~:D
    If...
  • joe logston
    joe logston Posts: 882
    edited March 2002
    looks great ron , how long did it take to build your equ. shelfs thats dam good handy work. you cant buy much better.
    tom hanks would loved to have your system on that island
    . rt-7 mains
    rt-20p surounds
    cs-400i front center
    cs-350 ls rear center
    2 energy take 5, efects
    2- psw-650 , subs
    1- 15" audiosource sub
    lets all go to the next ces.
  • goingganzo
    goingganzo Posts: 2,793
    edited March 2002
    thing must be beafy how much do your tv weigh? i have a 65 mit and it is 350lbs if yours is heavy you should add some cross braces for lateral suport
  • Ron-P
    Ron-P Posts: 8,520
    edited March 2002
    It did not take too long. I cut all the shelves Thrus night and painted/sanded/painted them. Once I cut the shelves I stacked them on top of eachother, used clamps and drilled the holes straight thru all of them at the same time. That way they were really lined up nicely. Friday night I put her all together. All-in-all probably about 8 hours.
    She weighs in a 170 lbs. I weigh in at 185 and I stood on it. I do not need cross-bracing because I have to center supports in the middle. If you look close enough, you can see'em. The back one is not covered with black yet. It is extememly solid. I tend to over build things. It's not going anywhere.
    Peace Out~:D
    If...
  • CHRIS
    CHRIS Posts: 454
    edited March 2002
    NO KIDDING??
    I would have never guessed!:rolleyes:
    Just bustin on ya dude!
    Chris :)
  • mantis
    mantis Posts: 17,322
    edited March 2002
    Nice job Ron,i'm looking forward to the new pic's of the green room.
    Dan
  • madmax
    madmax Posts: 12,434
    edited March 2002
    I like that Ron. Is there any protection to keep one of those rods on the floor from going through or is that not an issue? (I don't know much about construction). I may have to try one of these someday. Where do you find the hardware?
    madmax
    Vinyl, the final frontier...
  • Aaron
    Aaron Posts: 1,853
    edited March 2002
    Max,
    Order all the nuts, bolts, and washers from www.mcmaster.com. It will save you quite a bit over Home Depot. You can pick the threaded rods and the MDF (wood) up at Home Depot. They'll also cut the wood for you for free.
    Aaron
  • pensacola
    pensacola Posts: 269
    edited March 2002
    Alright, the customers are lining up.
    Now's the time to produce a shiny brochure—describing the thread stock, washers and nuts as "audio-grade", and the boards as "innert and noise-canceling", and the paint as "anti-resonant epoxy"—and slappin' a high-end price tag on the contraption. But ya gotta have a catchy name. And, it might help if you're pictured on the front in a white lab coat.;)
    Give War A Chance
  • Aaron
    Aaron Posts: 1,853
    edited March 2002
    It's already been done. Go to Salamander Design's web site.
    Aaron
  • Ron-P
    Ron-P Posts: 8,520
    edited March 2002
    I got the idea from tnt-audio. Here's the link: Flexy
    madmax, no real issure with the rods going thru.
    Peace Out~:D
    If...
  • johnnyamerika
    johnnyamerika Posts: 382
    edited March 2002
    Man you must be really proud of your theater, Ron. Everything about it you built! Congrats, dude!
    john
  • Ron-P
    Ron-P Posts: 8,520
    edited March 2002
    Thanks John. I am pretty proud of it. I enjoy doing everything myself. But, supporting a family I do not have tons of cash to dump into buying all the stuff. So, if I can make it instead of buy it, I will.
    Peace Out~:D
    If...
  • Aaron
    Aaron Posts: 1,853
    edited March 2002
    By the time it was all said and done with my flexy rack, I might as well have just bought a rack. It cost me about the same amount, not to mention the hours of work. Knowing what I know now, I definitely could have built it for less, though.
    Aaron
  • johnnyamerika
    edited March 2002
    The thing looks damn stable tho....I bet it was a pain in the arse getting that TV up on it.
