pro power amp on a HT
  • kuntasensei
    kuntasensei Posts: 3,263
    edited May 2013
    stuntman3 wrote: »
    K I'm bc. I bought a crown XlS2000 nd a 2way stereo converter. I hook up an old pair of tsi 400 guess what?those **** head woke up now I feel like I've been holding them bc. Now I'm thinking of making a DiY sub adding another pro amp. I have a JBL 4000W car sub dual voice coil 6ohm-W12GTI MKII. Any suggestions?
    Typing complete words and sentences that make sense would be my suggestion. Seriously... Not being a jerk, but I have no clue what you just said there.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • stuntman3
    stuntman3 Posts: 27
    edited May 2013
    I bought a crown XLS2000 pro power amp and a 2way stereo converter. I hooked it up with my old TSi 400.the sound is great. Now I'm thinking building a Diy subwoofer I have jbl 400w car sub rated 6ohm DVC. Model W12GTi MKII. I'm wondering if this sub will do the trick. I will add another pro power amp 2 drive it. Then Later use my RTis
  • kuntasensei
    edited May 2013
    I don't see a problem with that. But if you're building a sub with a decent sized woofer, keep in mind that you're likely going to need an amp that is solid down to 2ohm loads, depending on what woofer you use. Pro amps tend to be good for that. I'm running a SVS passive sub off the Crown XLS-1500 right now and ran it off a Samson 1000 in the past.
    Equipment list:
    Emotiva XPA-3 amp
  • stuntman3
    stuntman3 Posts: 27
    edited May 2013
    Its a JBL 4000W peak power-700W RMS power -18hz to 1000hz freq -dual voice coil 6ohm 3"diameter
  • stuntman3
    stuntman3 Posts: 27
    edited May 2013
    And its a 12inch sub
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2013
    stuntman3 wrote: »
    Thank you, now I know what you are talking about!
  • zingo
    zingo Posts: 11,258
    edited May 2013
    I just learned that Revel recommmends the Crown XLS DriveCore amplifiers for their speakers which says a lot about those amps, even though they are both Harman brands.
