bi-amping
mikkeljr
mikkeljr Posts: 4
I have emotive UMC-200 and UPA-700, im running tsi500 fronts. normal is 8 ohms. does the ohm rating change when bi-amped. upa-700 puts out 80x7 8ohms and 100x7 4ohms. im running 5.1, that leaves two open channels I can use to bi amp the fronts. how are the towers wired. anyone's input is helpful
Post edited by mikkeljr on
  • eclypse
    eclypse Posts: 595
    edited May 2013
    Never heard anyone metion that the ohms would lower if bi amped before so I would assume no.. no expert though.
    You will have to use a "Y" splitter for both fronts (L and R) and each end of the y would need to go to a seperate open channel on your UPA-700.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
    F1nut Posts: 51,923
    edited May 2013
    It's still not really bi-amping. That requires separate amps, each with its own power supply and active crossovers.
  • eclypse
    eclypse Posts: 595
    edited May 2013
    Also on the back of your speaker you would need 2 sets of speaker connections for Bi amping. If theres a metal bracket (jumper) that connects the sets, you will need to remove that first. Then from your amp you will need a set coming from one channel to either the top or bottom set of speaker connections and then from the other channel on your amp you will need to connect those speaker cables to the other open set of connections on the speaker. Then repeat for the other front speaker. So in the end you'll have 2 sets of speaker wires going to each speaker from a different channel on your amp. Each set from a different channel from your amp.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • eclypse
    eclypse Posts: 595
    edited May 2013
    Still gota give him more watts for the fronts in the end. If he's got the space why not see how it sounds.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • mikkeljr
    mikkeljr Posts: 4
    edited May 2013
    the reason I asked about the ohms because not sure how they are wired. with the bus bars connecting the two connectors, makes them parallel. if I remove them the ohms change?
    correct me if im wrong.
    if 8ohms coils
    driver 1 series to driver 2 is now 16 ohm load \
    these are paralleled by bus bars now a 8 ohm load
    driver 3 series to driver 4 is now 16 ohm load /
    if this is right, removing bars would leave a 16 load on each set and would draw less watts from amp
    F1nut Posts: 51,923
    edited May 2013
    F1nut Posts: 51,923
    edited May 2013
    mikkeljr wrote: »
    You're wrong, The speakers are rated 8 ohm nominal, period.
    edited May 2013
    mikkeljr wrote: »
    To answer the main question, you need a Y splitter for each front pre-out. Then that's 2 interconnect rca cables coming out of that Y with each going to a separate channel on the amplifier. Remove the brass plate on the back of the speaker that connects the top and bottom posts. Run your speaker wire from the top post to the amp, and the bottom post you'll run another set of wire. Do that for each speaker you want to supposedly bi-amp.
    Will it change the ohms ? No
    That being said, the TSI line is pretty easy to drive with any AVR. Maybe weigh in the cost of splitters, extra IC's and extra speaker cable. Also note the top portion of that speaker probably uses less than 20 watts, maybe even less than 10 so what ever power you feed it, what it doesn't use will be lost and not available to the other channels. Follow ?
    You didn't mention the receiver your using or other speakers either. Subwoofer ? Is there something your not liking about the sound that makes you want to use this bi-amp idea ? Personally, I would sell both amps and buy one better 2 channel amp and let the receiver handle the rest. Just my .02
  • mikkeljr
    mikkeljr Posts: 4
    edited May 2013
    I was just thinking because the emotiva umc-200 7.1 processor and the upa-700 are both 7 channels. Im only running 5.1 so I had to open channels still. The processor is compatible of 5.1 and bi amping the front channels with the two remainder channels
    edited May 2013
    Yeah, we get that my friend. But, for the sake of a movie sound experience why not just add 2 more speakers ? Seems that would benefit you more than bi-amping speakers that really don't need it.
  • mikkeljr
    mikkeljr Posts: 4
    edited May 2013
    Ok thanks guys
    pitdogg2 Posts: 27,203
    edited May 2013
    mikkeljr wrote: »
    if 8ohms coils
    no that shouldn't be the case it just separates the high and the lows both woofers will be the same
  • samreddevilz
    samreddevilz Posts: 18
    edited May 2013
    Yeah, we get that my friend. But, for the sake of a movie sound experience why not just add 2 more speakers ? hope you'll get some benefit from this....
    edited May 2013
    Why do you keep parroting others quotes. If you have nothing to add but others quotes as your own just go away.
    edited May 2013
    tonyb wrote: »
    see here^^^^^
  • chindman
    chindman Posts: 5
    edited June 2013
    The impedance doesn't change with your proposed arrangements because the high and low ends both have about 8 Ohms in their nominal frequency ranges, just much higher impedance for the frequencies that they don't service. So when wired in parallel they present 8 Ohms across the board, but are still 8 Ohms when separated at the frequencies that matter respectively for each driver. Unless you are really power starved and are getting noticable distortion from the amplifier (not the speakesr!) with your current setup there is no reason to consider biamping.
    F1Nut is right however, you have little to gain by bi-amping here. To get enough of what biamping has give to worth the trouble, you need low level crossovers AHEAD of two separate power amplifiers and bypassing/elimination of the crossover components in the speakers.(this reqiures brain surgery on the speakers) Unless you know what you are up to and have knowledge of the responses of the unprotected drivers in the particular speaker you are working with I do not recommend real world bi-amping since you can fry the tweeter a/o midrange speaker if the crossover is not set up properly before powering the amplifiers.
    The plus side is that with your proposed arrangement you aren't going to hurt anything, just don't expect much.
  • Poolgod69
    Poolgod69 Posts: 184
    edited June 2013
    Ok... I read it. And I will have to read it 5 more times to understand it...lol
    Marantz SR 5010
    Kenwood DR-V5070
    Polk RTi A9- Mains
    CSI A6- Center
    Elemental Designs A2-300 Subwoofer
    Panamax M4300-PM Power Conditioner
    Working on updating my set up :rolleyes:
