DB840 sub in LSI15's replace the stock 8"driver!!!!!
Damn, I just read this thread
http://www.polkaudio.com/forums/showthread.php?123136-SDA-Driver-Seals-Original-Foam-vs.-Mortite-vs.-Armaflex-Foam&highlight=mortite
What has become of this DarqueKnight?
That's quite a set of data he posted!“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
http://Vimeo.com/channels/stretchphoto -
The only Polk subwoofer that fits, is the db series. We tried to get an SR series subwoofer to fit but the magnet structure is too big and the Power Port becomes a problem. I'm sure you could find similar sized subs to the db and they would work but that was the subwoofer we actually played with in a chamber, tested and worked on in-house, to see if it would work as a better driver choice.
MarkCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I ended up using the gaskets on the replacements and left out the moretite and they fit fine. I did use all the screw holes though. I used Dynamat extreme on the woofer frames and also wrapped the ports. I notice a much fuller and substantial low end and I think it helps the overall sound of the 15's sound blend better from the high to low end.
"Thats great... but how does it sound"
http://www.burginmcdaniel.com/
http://mixonline.com/gear/reviews/audio_burgin_mcdaniel_komit/
Yamaha RX-A820 (networked with wireless bridge), Carver M-1.0t, Carver TFM-35, Carver C-1, Polk SDA1c's (x2 pair), Polk RTA 8tl's, Polk RTA 11tl's, Polk Monitor 5, Polk CS 400, Polk PSW 650, Rega Planar 3, Sony DVPNC555ES SACD/DVD, Panny 65" Plasma, Roku
2007 Tundra 5.7 TRD DC
Pioneer DEH-80PRS
Polk SR6500
SI BM 12" subs
Zed Gladius
Zed Deuce -
Question... When I disassembled the OEM woofer from the cabinet, the white lead was + and the yellow lead was -. But the leads have different sized connectors... If I fit the connector by size, the polarity is reversed. Did anyone else notice this? If so, how did you resolve it? Did you solder the connectors on correctly?
Connecting the wires by size gave me a very slight increase in bass so I am assuming that the polarity is incorrect. -
Aargh... my mistake, the wiring is correct... But I do not notice any increase in overall bass response, it actually sounds less... The bottom extension appears deeper, but the midbass response seems reduced. Some music that had thumping bass now sounds subdued but goes lower. Depth seems to have improved.
The mortite I bought from Home Depot was kind of dried out... it had a crumbly texture... is that normal? -
I dont think it`s supposed to be dried out. Also remember drivers need some time for break in.
But everyone says its better so you be the judge. -
It's less boomy which is what your describing. Your getting accurate bass for once. Turn it up and it's got more than enough bass.
Trust me I know.
What are you powering it with power wise and source wise?"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Anyone that has upgraded to the db woofers and still have the stock woofers laying around and wanna get rid of them please PM me. I would like to get 6 more of them for a "project".--Gary--
I'll have 4 of the stock 8" drivers available at the end of this week after I upgrade all mine.
I pm'd you Phred.--Gary--
pm'd you Gary.Things work out best for those who make the best of the way things work out.-John Wooden
A bit off topic --- has anyone thought of or tried DB1040 on Lsi25? I'd be very interested to hear the results.
- Online - Focal Solo6 BE, Polk PSW10, Focusrite Saffire Pro 24 DSP, Lenovo x220t
- Music/HT - Lsi25, Lsi9 (Vr3), Lsi7, LsiC, Pioneer SC-68 & BDP-62FD, PS3
We had problems with the simple idea of just using the larger version, on the larger version. It's more than a few issues including proper clearance of the power port and cabinet volume were just two problems. The volume isn't a huge issue but it became a project that had more work involved and it wasn't just a drop in replacement like the smaller model. It was abandoned and I'm not aware of anyone doing this mod, nor would I suggest it unless you had the money and time. Just my opinion.
Mark
Polk Audio CSCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I appreciate your reply. No, I am not brave to try.
Plus, honestly, I don't even like the LSi25 so I would put forth no more effort than I already have. The fact you can drop-in and plug in the LSi15/dB Series woofer is just the sweetest deal ever. The mod has been done here over a dozen times, it works and I've yet to hear any complaints.
It all stemmed from an email I sent to Engineering many years ago about, "What would you do to mod the LSi series?". And the first model out of the response was the LSi15. The exact driver was immediately mentioned and a couple smaller issues that were also passed on and can be found in the threads about this modification.
Clearly, they had messed around with this idea and if you have ever met the folks from that area of Polk HQ, they like to try things and test theories. If they didn't we wouldn't be here and we wouldn't even care about this in the first place. These folks love their job and they love to push the envelope, even if its simple things.
That's why Polk Audio has such a following here and why they(HQ) think its weird when we want autographs on vintage drivers, literature and sometimes even body parts when we get the chance to do tours in Baltimore(2005/ 2008/ 2012....am I getting the years' right guys?). Other manufacturers started doing stuff like this YEARS after we started to do it and make it painfully public. Suck it Carverfest.
Hahaha! Thanks for the great morning laugh Mark. -
Are there any other options besides the polk replacement for this driver that anyone has found? I am not a fan of their look.
PubFiction wrote: »Are there any other options besides the polk replacement for this driver that anyone has found? I am not a fan of their look.
You can't see it once you put the cover back on. Plus the subs face sideways so you shouldn't see them regardless lol"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
well mine are positioned so you can see them and I liked to keep the grill off.
If you are watching the drivers when listening, you are NOT listening.Political Correctness'.........defined
President of Club Polk -
PubFiction wrote: »well mine are positioned so you can see them and I liked to keep the grill off.
You either have way to extreme of a toe in or like F1nut says, you're doing it wrong. Why do you dislike using the grill? -
I guess you're SOL then.PubFiction wrote: »well mine are positioned so you can see them and I liked to keep the grill off."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Lots of people like to have the grilles off I don't get the big deal? They dont really add much to the look other than provide a cheap cover up for bad looking or gaudy speakers. But its fine, obviously their is not a known alternative.
Grills serve a few purposes that you seem unaware of. First and foremost, they are an integral part of the speaker's acoustical design. They keep dust and grim off the drivers. They keep little fingers from poking. So, put your grills back on.Political Correctness'.........defined
If you're serious about finding another sub that has the same parameters, this is what you want to look for: http://www.polkaudio.com/products/db840
Be advised, you will probably end up with another car sub which will either look similar or much more gaudy.
Resonant Frequency 49 Hz
Xmax
Xmax Linear .51 inch/13 mm (peak to peak)
MMS 67g
BL 10.3 Tesla Meters
CMS 157.6 Micro Meters
Recommended Enclosure Sealed/Ported/Bandpass
SD 35.65 sq inch/ 230 sq cm
VAS .42 cubic feet/11.9 L
QTS .6
QES .6
QMS 14.1
Diameter 8" (20.32cm)
Cut-Out Diameter 7 1/8" (18.10cm)
Nominal Impedance 4 ohms
Efficiency 85 dB"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Can we get some long-term impressions from those that made the db840 swap?
Has anybody reverted back to the stock woofers? -
Lol the lack of posts after doing the mod are due to the members enjoying music too much to post lol.
They sound MUCH better. I sold off my stock woofers and haven't looked back."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
changing the woofes made the bass a lot tighter... The original drivers tended to be a bit boomy.
Definitely worth doing. The bass is a lot tighter! The mod is cheap and easy to do so it is a no brainer. Sounds EVEN better after upgrading the crossovers
[The Ever-Evolving System
LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD. -
FINALLY pulled the trigger. Have owned the 15's for over a year now, so figured it was time. Under 90 bones. Will be here Friday.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
