Surround 9000
Doogiewaldo
Doogiewaldo Posts: 2
edited December 2013 in Basic Hookup/Wiring Questions
I have just tried to hook up my second surroundbar9000. After hooking it up, it turns on automatically, and I can't control the system from neither the remote or touching the bar controls.
Post edited by Doogiewaldo on
  • rpf65
    rpf65 Posts: 2,127
    edited April 2013
    What do you mean can't control it? If you mean the volume, I think you have to turn the tv volume up to max. That will send a strong enough signal to the sound bar. The sound bar has a built in amp, so the tv, after setting to max, will no longer affect volume.
  • Doogiewaldo
    edited April 2013
    It turns on automatically and sound is working. I just can't control any of the functions such as on/off, volume, source, or the learn button. I've touch all around the areas on the surroundbar and the remote does not respond either
  • rpf65
    rpf65 Posts: 2,127
    edited April 2013
    May be a bad battery, I'm sure you pulled the little tab off the battery. Try replacing it, if that doesn't work give customer service a call, those people are great.
  • Jimmythev
    Jimmythev Posts: 2
    edited September 2013
    I am having the exact same problem. It just started, and now the audio bar is not responding to the remote or touching the front panel. I have no ability to adjust the volume. I've unplugged it, plugged it back in, no luck. Has anyone ever solved this problem?
  • Jimmythev
    Jimmythev Posts: 2
    rpf65 wrote: »
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello,
    Welcome to Polk's forum, sorry there's a problem. It would be best to give Polk's CS department call on Monday at: 1-800-377-7655 or email them to: polkcs@polkaudio.com.
    They'll help you.
    Regards, Ken
  • polrbehr
    polrbehr Posts: 2,846
    ^^^^Reported^^^^
  • 03SONIC
    03SONIC Posts: 46
    edited November 2013
    Ever get this fixed?? I am having the same problem with a new one I bought?
    F1nut Posts: 51,916
  • 03SONIC
    03SONIC Posts: 46
    Hello,
    They'll help you.
    Regards, Ken
    Ken new bar sent I have the same issue???
