Powering Rti A7s
trohan415
trohan415 Posts: 5
edited May 2013 in Electronics
So I am looking to putting a little more power into the Rti A7 front speakers I have had for awhile now. I have seen on my forums that it would be benificial to bi-amp them. Could anyone recommend any amps for my situation? My current setup:
7.2
Fronts: Pair of Rti a7s
Sides: Pair of Tsi 200s
Backs: Pair of Fxi a6
Center: Csi a6
Subs: Pair of BIC America V-1220 12-inch 430-Watt down firing
Receiver: Denon 3313(125 Watts per channel)
Post edited by trohan415 on
  • kuntasensei
    kuntasensei Posts: 3,263
    edited April 2013
    Forget bi-amping. Just get a quality 3-channel amp for your mains and center and you're good to go. If you're looking for specific recommendations, what's your budget?
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
    edited April 2013
    Your subwoofers are doing all the heavy lifting power wise, I see no reason to even add an amp untill you move up to harder to drive speakers. Sure, some benefits will be had by adding an amp, but may not be the bang you had in mind.
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2013
    +1 Get a 3-5 channel amp of at least 200wpc @ 8ohms sit back and enjoy. This will allow your speakers to operate to their full potential as well as enough power to manage just about any speakers you might get in the future.
  • jumpindick
    jumpindick Posts: 428
    edited April 2013
    halo parasound
  • chumlie
    chumlie Posts: 8,658
    edited April 2013
    jumpindick wrote: »
    halo parasound
    That will make those 7's sing.
  • fokakis1
    fokakis1 Posts: 36
    edited May 2013
    I tried bi-amping my A9's (passively) just to see for myself if there was a difference. I also tried by-wiring them with dual 12 AWG wire. I personally noticed absolutely no audible difference at any volume level. One amp channel per spx connected with one 12 AWG wire is good for me. I cannot speak for active bi-amping.
    Full 8.2 with:
    Onkyo TX-NR818
    Emotiva XPA-3
    Audiosource Amp One/A
    Behringer EPQ2000 w/quietfan mod
    Panny BDP310
    3TB NAS
    Ethereal ESP601R
    Monster HTS 1650
    Epson HC-3020
    120" DIY 1.0 Gain Screen
    Polk Rti A9 fronts
    Polk Rti 6 surrounds
    Polk Rt/Fx rear surrounds
    Polk Rti 4 front heights
    (Phantom center):wink:
    SVS 12's x 2 (DIY passive):eek:
    ATS Acoustics DIY panels
    Harmony 650
    Nostalgia Electronics CCP-510 MovieTime Popcorn Cart
