Powering Rti A7s
trohan415
So I am looking to putting a little more power into the Rti A7 front speakers I have had for awhile now. I have seen on my forums that it would be benificial to bi-amp them. Could anyone recommend any amps for my situation? My current setup:
7.2
Fronts: Pair of Rti a7s
Sides: Pair of Tsi 200s
Backs: Pair of Fxi a6
Center: Csi a6
Subs: Pair of BIC America V-1220 12-inch 430-Watt down firing
Receiver: Denon 3313(125 Watts per channel)
7.2
Center: Csi a6
Post edited by trohan415 on
Forget bi-amping. Just get a quality 3-channel amp for your mains and center and you're good to go. If you're looking for specific recommendations, what's your budget?Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Your subwoofers are doing all the heavy lifting power wise, I see no reason to even add an amp untill you move up to harder to drive speakers. Sure, some benefits will be had by adding an amp, but may not be the bang you had in mind.HT SYSTEM-
lsi 9's -
kuntasensei wrote: »Forget bi-amping. Just get a quality 3-channel amp for your mains and center and you're good to go. If you're looking for specific recommendations, what's your budget?
+1 Get a 3-5 channel amp of at least 200wpc @ 8ohms sit back and enjoy. This will allow your speakers to operate to their full potential as well as enough power to manage just about any speakers you might get in the future.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
halo parasound
That will make those 7's sing.jumpindick wrote: »halo parasound -
I tried bi-amping my A9's (passively) just to see for myself if there was a difference. I also tried by-wiring them with dual 12 AWG wire. I personally noticed absolutely no audible difference at any volume level. One amp channel per spx connected with one 12 AWG wire is good for me. I cannot speak for active bi-amping.Full 8.2 with:
Onkyo TX-NR818
Emotiva XPA-3
Audiosource Amp One/A
Behringer EPQ2000 w/quietfan mod
Panny BDP310
3TB NAS
Ethereal ESP601R
Monster HTS 1650
Epson HC-3020
120" DIY 1.0 Gain Screen
Polk Rti A9 fronts
Polk Rti 6 surrounds
Polk Rt/Fx rear surrounds
Polk Rti 4 front heights
(Phantom center)
SVS 12's x 2 (DIY passive):eek:
ATS Acoustics DIY panels
Harmony 650
Nostalgia Electronics CCP-510 MovieTime Popcorn Cart
