Denon - Classe - Odyssey - Panamax - Audioquest
george daniel wrote: »Is the warranty still good/valid if I buy this(that would make me the third owner),,and is the romte issue with the pre or the remote itself.
It would make you the 2nd owner. I never registed it with Klaus because I was trying another tube preamp out at the time and did not know if I would keep it or not. I only inquired about the updates before I purchased it to make sure the seller was truthful in his description. It seems like a remote issue. The previous owner informed me that Alex asked him to send it back to fix the issue but he never got around to it. I used the volume control on my mac mini so it was never an issue for me. The serial number is on one of the pictures. Klaus could probably be contacted to make sure the warranty was transferable. Thanks -
Friday Bump for the Candela!
Monday bump for the Candela.
RDB clear your inbox.
Ahh you're the guy with the Candela FS on CAM. I thought the name was familiar.
Can't buy but GLWS. Certainly a very nice piece of gear. -
Thanks and yes it is a nice piece of gear. Out of all the gear I was selling, I figured this piece would go first. I have seen Candela's go for more than what I am selling mines for.
Tuesday bump. -
I will take it, PM coming.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
OK, payment and shipping instructions sent, check your PM inbox.
I've been trying to resist this, but finally gave in....can't wait to see how it sounds.
Thanks!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Thanks!
I did receive the Candela last Thursday, but have not had a chance to try it out yet, too busy lately. First pre with HT bypass, not sure but I think I just connect the outputs from other pre here and when I select bypass the Candela just passes the signal through unchanged??:cool:Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
