Speaker wire Age?
chiptouz
All,
I am using 12gauge monster cable for my fronts and center. The cable does not state what the model number. Is there any reason to replace these with new 12 guage. I do not see any type of corrosion inside the sleeve. The cable was bought in 2000.
Thanks,
Chip
Thanks,
Chip
Sharp LC-80uq17u
Denon 4520ci Receiver
OPPO BDP-203 Blu-Ray Disc Player
Monster HTS 3600
Polk RTi-a7 (fronts)
Polk CSi-a6 (Center)
Polk TC-60i (Rear & Surround Rear)
HSU Research VTF3-MK4 (Sub)
Logitech Harmony elite (Remote)
Monster HTS 3600
I'd like to know the same as I also am using some Monster brand 10-12 gauge wire for the past 10 years now.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
Just do a visual inspection. Are the copper wires corroded? Are wire strands broken? Is the insulation crumbling or cracked or deteriorating?
Sounds all good then
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
I was just down in the basement. I came across an old trail light set-up that did as a DIY project back in the 1970's. So we used what ever wire we found and it was outdoors for some years. Now 40 years later it doesn't look all that bad.
Still using Kimber Cable July 1990POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
One of my monster cables (center channel) had some corrosion on them. It's well over 12 years old and the end that plugs into the binding post has turned greenish black. I just replaced them with new ones. All the other channels were fine.SRT Seismic System with dual PSW1200's
RT5000 x 2
RT2000p
CS400i
CS350-LS
LS F/X
PSW650
PSW1000 w/Dayton SPA1000
DSW MicroPro 4000
Adcom amps
Pioneer Elite SC-89
Pioneer PLX-1000 Turntable
PS4
XBOX One
MIT Interconnects
BJC -
As long as its not black, rubber isnt dried out, and the conductor isnt just falling apart you should be good. Speaker wire is cheap on Amazon and it cant hurt to replace 13 year old wire.B&W CM9Classé Sigma
I think it's fine.Samsung UN55C6500 55" LED
Onkyo TX-NR3007
Polk Audio RT5000
-RT3000 front
-CS1000 center
-FX1000 dipole
Polk Audio PSW1000 5.1 sub
Polk Audio microPRO 4000 x2 5.2 subs:biggrin: -
Speaker wire, and all cables, should be replaced every ten years, if not sooner. This is due to electron depletion, and quantum settling on the atomic level, which eventually results in degraded sound quality. Assuming your hearing is up to par.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Or the electrons just get tired. -
I guess I need some new wire...Samsung UN55C6500 55" LED
Onkyo TX-NR3007
Polk Audio RT5000
-RT3000 front
-CS1000 center
-FX1000 dipole
Speaker wire, and all cables, should be replaced every ten years, if not sooner. This is due to electron depletion, and quantum settling on the atomic level, which eventually results in degraded sound quality. Assuming your hearing is up to par.Or the electrons just get tired.
You guys are funny! And how many physicists have observed Quantum effects in strands of copper speaker wire? The actual copper in my wire will see me in the "grave" and then some?
And hearing "disintegrates STEADILY" with age. Every 5-10 years you lose quite a bit of high end, and eventually, you have to use a GIANT CONE just to hear your grand kids asking for a snack! Copper is unaware of "your" hearing loss and does not care in any case.
I'd say it's time to expand your horizons.
lsi 9's -
say whatttt? link -
hosedagain wrote: »say whatttt? link
It's a joke. -
Don't worry about your speaker cables. What you have to worry about are your power cords. Just spend a few hundred thousand dollars(or only a few hundred if they're on sale) and upgrade them and you will be in audio heaven. Just look guy a guy named Patrick(or Cheesy) - he's got the hook up.Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
1 word. Ohmmeter.
You can snip the ends just in case, re-strip the ends, and use some de-ox or similar for peace of mind. Or, you could use banana plugs. Or lastly, solder the exposed leads - that's my preference if I'm using bare wire hookups.11.3 Theater
RTi A7 Fronts - CSi A6 Center - 65-RT DSX Wides - RTi A1 DSX Highs - FXi A6 Rears - FXi A6 Surround Backs
eD A5-350 (L-LFE) - eD A5-350 (R-LFE) - SVS 20-39+ (Rear-LFE) - Aura Pro x 8 Seats
Onkyo TX-NR3010 (11.3 Neo:X) - Sony TA-N9000ES Amplifier
JVC RS-20u - Elite 120" 1.3 Gain - XBMC Processor - TrippLite 30A Full Theater Backup
2.1 Studio / PC
Mackie HR824 Powered Monitors - Infinity Kappa Perfect 12" DIY
Aune USB 24/192 DAC HPA - Sennheiser HD650/600 -
Soldered wire ends make for the best connection because the soldered speaker wire deforms as you tighten the electric connection to the speaker and amp. -
No solder tinned stranded wire ends are bad. Under screw terminals, the solder tinned wire ends will with time and temperature changes, cold flow which will allow the terminal to loosen.
1 word. Ohmmeter.
+1. I totally agree!
It's how you can know everything there is to know about all the DC you listen to! Simple and downright effective. There isn't anything to more to know about that! It's a done deal now!
CJA so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping." -
1 word. Ohmmeter.
can you tell us how to use one, how to read it, what to look for etc -
I don't think Age is a big fact.... if you can preserve it, then it'll work for a long time.
Have been using the same 12 ga monster wire since 1988.
