Question about EZ Set/EQ settings on my Harman Kardon receiver
HTguru1982
HTguru1982 Posts: 1,066
edited April 2013 in Electronics
Okay I ran the EZ Set/EQ on my receiver(have always configured it manually in the past). For my speakers(listed in sig below), it wants to set all of my speakers to large with a 40hz crossover point with the bass being directed to both my subwoofer and front LR speakers. Is this the right way to run things? Should I change them to small with a 80 or 60hz crossover and let the sub handle the bass? I would think that my all speakers could handle frequencies down to 40hz but I would be worried about whether the receiver could handle it. Any suggestions?
Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
Post edited by HTguru1982 on
  • rpf65
    rpf65 Posts: 2,127
    edited April 2013
    I would personally set them all to small, and cross over at 80 hz. Auto-cal programs are not perfect, and you probably hear differently than that mic. As long as you don't go below, in this case, 40 hz all will be well. Let the sub do what it was designed to do.
  • devani
    devani Posts: 1,497
    edited April 2013
    I've set mine to 60Hz....pretty similar to what I have....my 445 is okay for powering 5 speakers with 60-hz setup at reference level but we hardly listen at reference level anyway....it's too loud for my family...ultimately let your ears decide..
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • HTguru1982
    edited April 2013
    Thanks for the help guys. I'll go ahead and set everything to small with the crossever @ 80hz.
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    tonyb Posts: 33,070
    edited April 2013
    Try it both ways and see what floats your boat. You won't hurt anything, and all this isn't written in stone.
