Monitor 60 help
ryu4000
ryu4000 Posts: 9
Been having my polk monitor 60 for almost 5 years now love these little guys but having a little problem at moment sound seems to shift from time to time from right to left.I also ran test tones and well the speakers test tones sound a bit different i have move them from one side to the other and it seems to follow that one speaker.I'm hoping you expert here can help me with this if needed i can make a video of the sound of both front and left sound different during test tones.
  • rpf65
    rpf65 Posts: 2,127
    edited April 2013
    The first thing I would do is check that the jumper in the back is securly connected. Better yet, remove them and replace with good speaker wire.
  • ryu4000
    ryu4000 Posts: 9
    edited April 2013
    Brought some brand new speaker wire and replace both the old one's and still getting the same issues.
  • ryu4000
    ryu4000 Posts: 9
    edited April 2013
    I'm going try to explain as best i can i was watching Django Unchained blu-ray and you can hear high frequency coming from right side but you don't hear it that much on the left side.I don't know if this is how the movie is encoded or what i'm getting the dts-ma so i know i'm getting the highest sound possible.
  • rpf65
    rpf65 Posts: 2,127
    edited April 2013
    If the sound issue remains with the same speaker, and all wiring is tightly connected, the problem is with the speaker. Since it you can hear the sound evenly distributed to both speakers occasionally, it is probably not an actual speaker, but either internal wiring or the cross over.
    Does it seem if all sound from the speaker is dropping out, or just certain freqs?
    Eventually you'll have to get inside the speaker, but if it may be just a bad/loose connection to one of the speakers at either the speaker itself or cross over. Just trying to narrow it down a little.
    May want to check a different DVD/BD/CD that has played normally before, just on the off chance that you haven't tried that yet. Could be an issue with the one you were watching, be it the DVD or problem with the player not being able to read it properly.
  • ryu4000
    ryu4000 Posts: 9
    edited April 2013
    certain freqs when one side sound louder so far just right side i let audyssey do my settings they put my front full band since i have no sub and surrounds 40 and center 60 that's the cross over.
    Specs
    Avr is denon 1612
    Front left and right is Monitor 60
    Surrounds is monitor 40's
    Center is polk cs2
    audyssey
    Front left db -6.0
    Front right DB -5.0
    Center -8.0
    Surround left -6.0
    Surround right -5.0
  • custopper30
    custopper30 Posts: 252
    edited May 2013
    Like others have been saying, my best well educated guess is that if the sound is following one speaker, that means there is something wrong with the other one. The problem could be a varieties of things too.
    Receiver: Denon 1912
    Speakers:
    Fronts: Polk Audio Monitor 70s (x2)
    Rears: Polk Audio Monitor 50 (x2)
    Center: Polk Audio Monitor 70
    KLH Sub GFX-550
