PSW10 distorting on low frequencies
MovieNut
MovieNut Posts: 1
edited April 2013 in Troubleshooting
Hi. I'm new to these forums but have been battling with this issue since I purchased this home theater package (RM6750) 3 years ago. The problem is my PSW10 sub is distorting on explosions and other low frequency sound effects leaving the base making a sloppy / warbly sound. The distortion is extremely distracting during movies, sounding almost like a busted speaker. I've sent it in to polk who found nothing wrong with the speaker or amp, but replaced the amp just in case. It did not help. I've also tried changing the cable, which did not help either. If it helps, the distortion can be minimized only by lowering the volume on the speaker itself.
Here are my settings:
Speaker (PSW10)
Frequency: 120Hz
Volume: 40%
Receiver (AVR-1909)
Frequency: 120Hz
Volume: +3db
All other speakers (RM6750)
Frequency 120Hz
Can anyone help?
- Nick
Post edited by MovieNut on
  • rpf65
    rpf65 Posts: 2,127
    edited April 2013
    Turn the volume knob on the speaker, itself, down. My guess is your avr has it set at -10 db, or whatever is the lowest setting. Anything +/- 5db and the speaker volume knob needs adjusting
  • BlueFox
    BlueFox Posts: 15,250
    edited April 2013
    It's to loud for that sub. If you want loud distortion free sound you need two basic items. First, is lots of good, clean, power. Second is speakers capable of handling loud sound levels.
