pioneer PL570 TT
snake1
snake1 Posts: 567
edited April 2013 in Electronics
As the title says I'm looking at this turntable on CL. Is it a decent model? Asking $50.
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
Post edited by snake1 on
  • unc2701
    unc2701 Posts: 3,587
    edited April 2013
    Ask if it's got woodgrain. There's two pioneer 570's: 80's plastic one that's belt drive and crap crap crap. 70's direct drive one that's got woodgrain on it is pretty solid and worth about $200 and up depending on the precise condition.
    Backburner:Krell KAV-300i
  • snake1
    snake1 Posts: 567
    edited April 2013
    Looks like black plastic in the pic
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • unc2701
    edited April 2013
    It's probably garbage, then. $20-$30, seems to be the going price, but I would wait for something better to pop up. The 70's pioneers show up on CL all the time and they're pretty solid. I've got a PL-530 that I still use on & off. They pop up on CL frequently and you can probably score one for under $100. Since people are bad about describing things properly, the easiest thing to look for with the pioneers is whether it's got the woodgrain plinth. Those are almost all direct drive and decent performers as long as they're undamaged.
  • snake1
    snake1 Posts: 567
    edited April 2013
    Thanks for the help! I'll keep looking!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • skrol
    skrol Posts: 3,452
    edited April 2013
    There was a black version of some of the Pioneers in the 70's. Google Pioneer PL-570x. There was also a wood grain PL-530 and black PL-530x.
    I did see the later PL-570 black plastic. It has the straight tone arm instead of the S arm.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • snake1
    snake1 Posts: 567
    edited April 2013
    Here is a pic. Does this help? Looks like it has a straight arm and the price has dropped to $40!
    Also, will this hook to my AVR via RCA cables??
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • snake1
    snake1 Posts: 567
    edited April 2013
    Bump! Can someone take a look at this? I think its the right one since it has the straight arm??? Deal is a little better at $40.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • boston1450
    boston1450 Posts: 7,758
    edited April 2013
    Does your avr have PHONO ? If the turntable does NOT have a built in amp it will need to be hooked up to PHONO ONLY
    online GOOGLE this..... Audio Technica AT-PL60 and you can get one to your doorstep for 71.00 BRAND SPANKING NEW---- its a great start up turntable. Sound is wonderful----price is right---- it has a built in amp.. You can use it on any stereo with/without PHONO-- did i forget to say BRAND NEW-- yes it is 30.00 more. But what to heck
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    edited April 2013
    Heck you can hook it to your TV without a stereo and use this turntable. I have owned one and there not too bad.....there is a button on the back
    Hook up to phono-- or --hook it to any other rca port (cd-tape-accs)......i apologize. I just read up your receiver HAS phono. So you should be good to go
    Randy-Maine
    by David WMG
  • boston1450
    edited April 2013
    I would say with the gear you have i would invest my money on a nicer higher end tt...IMO--- good luck with your decision.
    Randy-Maine
    by David WMG
  • boston1450
    edited April 2013
    I apoligize..i misunderstood your question..if that unit doesnt already have cables with it. Yes i would think you would use rca cables to hook it up. As i have a Technics that is like that..the Pioneer looks to be clean from what the picture you provided....the receiver you have is a TANK from what i read up on it. It must do a great job also......
    Randy-Maine
    by David WMG
  • snake1
    snake1 Posts: 567
    edited April 2013
    boston1450 wrote: »
    I'm going to give the guy a call about it. If its got RCA jacks (which I'm sure it probably does). I'm hoping someone can chime to tell me if its the better one since it has the straight arm and direct drive. I also hope it has the 45 attachment. Oh, and yes, my Onk has Phono inputs! And yes, it is indeed a Beast!! I'm nothing but pleased with it!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
