Atrium 55 outdoor speakers, how best to drain them.
brokirk
brokirk Posts: 1
edited April 2013 in Troubleshooting
I assume that I will have to drill a hole somewhere, but having no prints, I'm looking for info on best place to drill.
Post edited by brokirk on
    F1nut Posts: 52,009
    edited April 2013
    They are suppose to be water tight. Do you actually have water in them? If so, take them apart to drain and figure out how the water got in.
    edited April 2013
    You shouldn't have to drain them....ever. Do not drill holes in the speakers if it's just because you think you need to drain them, because you don't. The only holes should be to attache the bracket to the house.
