rule of thumb please
Willow
Willow Posts: 11,222
edited June 2004 in Speakers
what is a good rule of thumb for distance or your mains from the tv. I have heard 3 feet !??
Post edited by Willow on
  • ch47d
    ch47d Posts: 18
    edited June 2004
    As a rule of thumb, your mains should be as far apart from each other as you sit from them. In other words picture an equalateral triangle with you and each main forming the points.
  • Willow
    edited June 2004
    Im about 11 feet away from the tv and speakers....my speakers are 6-7 feet apart
  • PolkThug
    PolkThug Posts: 7,532
    edited June 2004
    That's about how mine are. When I had them in "triangle" configuration, they didn't sound as good for music.
    VR3 Posts: 29,400
    edited June 2004
    I have mine where they will fit. Which works quite well. One is about 1 foot (or less) from the TV, and the other is 4 or so feet from the TV -- and it has perfect center imaging over the TV. Pretty good.
    I usually tell people to get ATLEAST 3 feet on each side of your center, if you can do more...do more
