Received the White Night Power 2m Power Cord as a Temp Replacement
1234568
  • mrbiron
    mrbiron Posts: 5,720
    edited April 2013
    Whaaaa Da Fuuuunk did i just read?!?!?! And i read all of it. The nose bleeds go away right?
    This guy makes pepster look like a certifiably, sane individual.
    Im really confused why you would want a 5m cable? Look at all that useless cable you have winding around your dumb-as_ looking Pier 1 columns. On a side note, those sweet playdoh coverings really accent the primer white walls of your audiophile apartment.
  • theshawn
    theshawn Posts: 70
    edited April 2013
    I hear white vans seriously have magical tonal qualities that pass through the wires as you clip them to wrap in compatible sequence within the sleeve during assembly. The inner resonances echoing within the van create a force field of sorts that impregnates into the finished cable thereby canceling out all possible distortion within the cable by using distortion to cancel distortion which results in a distortion free cable. In addition, when building longer cables within the van the extra length actually results in massive increases in tonal resonance distortion absorption because as we all know the longer the cable the better the signal transfer.
    It will be close, but I think I have enough equity in my house to make a purchase possible. *fingercrossed*
  • B Run
    B Run Posts: 1,888
    edited April 2013
    mrbiron wrote: »
    If you put your computer on top of the $7,500 Rock Tower Night Angel Vibration Pads, the bleeding will finally stop. Oh and music will literally make love to you while you listen to it.
  • cheezy
    cheezy Posts: 148
    edited April 2013
    Specs:
    CMS 65 Frequency response (+/-3dB) 45Hz-28kHz
    CMS 50 Frequency response (+/-3dB) 55Hz-28kHz
    What bass???
    Bass in the 45hz region. It doesn't have to be at 28- 30hz to hear bass. With different cables, the bass resolution and hardness differs with same speaker. There is more to it than just frequency range.
    HTguru1982 wrote: »
    Are u kidding? U must be. Those cables add at least an extra 20hz extension to those speakers. They shouldnt even be considered "speakers" anymore. "Magic" is more appropriate. Remember you can now hear the "background of the background".
    It is very detailed. I can hear hear what spectators are saying in the background, almost like background of the background, especially in performance in stage.
    mrbiron wrote: »
    For greater noise cleaning power. Longer the better.
    I think those columns make good presentation. It looks chic. That's not an apartment. It's a house.
    :surprised:
    cheezie
  • zingo
    zingo Posts: 11,258
    edited April 2013
    DSkip wrote: »
    DAMN! I've never heard spectators behind the musicians. Must be some kind of cable you got there.
    The best you've never owned...
  • cheezy
    cheezy Posts: 148
    edited April 2013
    With the exception of Patrick's alien crystal technology, the longer power cords benefit more from noise cleaning in general. And audio cables benefit more from shorter length as the timing is more critical.
    I just saw price increase on the White Night Power 5M. The performance price is now at $250,000. You could buy a Ferrari 458 Italia or Lamborghini Balboni Valentino LP550-2 with that money.:eek:
    cheezie
  • decal
    decal Posts: 3,205
    edited April 2013
    cheezy wrote: »
    With the exception of Patrick's alien crystal technology, the longer power cords benefit more from noise cleaning. And audio cables benefit more from shorter cables as the timing is more critical.
    cheezie
    I just put in my order for 3 of them. I'm so glad you started this thread, I'd never have known the exceptional traits of this product otherwise. I was going to buy a new house but after reading your reviews, I think an upgrade to my system would be more beneficial. I have no doubt this PC will take my modest system into another realm. Thanks again.
  • cheezy
    cheezy Posts: 148
    edited April 2013
    decal wrote: »
    You ordered three of White Night Power 5M? Wow, congrats! Do you have a passive audio system or active? Either way you go, you will hear the difference immediately. At first I was part skeptical before buying cables from Patrick, but I took a shot at it. So glad I did. One of the things you will notice the most is the size and depth of soundstage. Very spacious sound with full of details and clarity.
    Right now my PC is suffering with fan noise for the CPU. Even though the system is hidden inside the cabinet I can still hear fan noise a bit. I will be replacing the heatsink and fan with a quiet one (or heck, might watercool it) and take another video of it.
    cheezie
  • ViperZ
    ViperZ Posts: 2,046
    edited April 2013
    ZLTFUL wrote: »
    Gonna let you in on a little secret cheezy...they're mocking you.
    I know...it is shocking to see that kind of hatred and vitriol in the world.
    But I am sure if you went and necked yourself, the mocking would stop.
    ZLTFUL, how could you say that?! I just saw a guy trading in his Ferrari Enzo collector's edition for a pair of those White Night cables, because he never heard spectators in the background.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
    F1nut Posts: 51,722
    edited April 2013
    Yeah, keep telling yourself that and maybe it will come true.
  • BlueFox
    BlueFox Posts: 15,251
    edited April 2013
    And keep rubbing your magic 'stone'.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited April 2013
    Cheezy, I think you may find that your search for audio nirvana may be assisted with these:
    http://www.cafepress.com/+audiophile_classic_thong,707488940
    "Panty-minimalists love our casual thong that covers sweet spots without covering your assets; putting an end to panty-lines. This under-goodie is "outta sight" in low-rise pants. Toss these message panties onstage at your favorite rock star or share a surprise message with someone special ... later"
    Specs ?
    5.8 oz. 100% Ultra-fine combed ring spun 1x1 baby rib cotton
    Only $12.50 separates you from possible bliss (doesn't include shipping though).
    Or perhaps this may be more appropriate ?
    http://www.cafepress.com/+audiophile_nervosa_classic_thong,727795057
    A lot of choices to be made, and it's your rabbit hole, but .... go for it ! :wink:
    DISCLAIMER: no brand bashing occurred during the making of this post. YMMV. No returns accepted for undergarments. :eek:
  • Drenis
    Drenis Posts: 2,871
    edited April 2013
    Shame on Polk for keeping something like this a float...
  • B Run
    B Run Posts: 1,888
    edited April 2013
    I thought this would have been closed a long time ago. Funny how much Cheezy's writing style matches the Coconut Audio website (using the term website loosely).
  • ken brydson
    ken brydson Posts: 8,996
    edited April 2013
    Drenis wrote: »
    Entertainment value bro...
  • Drenis
    Drenis Posts: 2,871
    edited April 2013
    Its so boring and old now! :razz:
  • David R
    David R Posts: 134
    edited April 2013
    A friend told me about cables that cost that much but it is beyond my imagination.
    Panasonic 65" Plasma - Panasonic Blu-ray. Onkyo TX-NR809 RTi A7s fronts - MK CS150s surronds.
  • Jhayman
    Jhayman Posts: 1,548
    edited April 2013
    No it's not it's 100% Pure Cheeze..
    what's Great about him you can't get a rise out of him at all..
    very calm and Cool..Just like Coconuts
    Drenis wrote: »
  • PolkieMan
    PolkieMan Posts: 2,446
    edited April 2013
    YEA he's right!!! from now on I am only going to listen to my Monitor 4A's I keep out in the garage:lol:
  • ken brydson
    edited April 2013
    Can I plug it into my ipod and make it sound better?:smile:
  • Geoff4rfc
    Geoff4rfc Posts: 2,817
    edited April 2013
    @ cheezy, I'm a professional motocycle road racer, it's not what you can do for me, but what I can do for your product.
    Sponsor me for 20K and I'll advertise for you and your product. I'll advertise up and down the west coast and nation wide as my photos will be posted on many websites.
    Oh yeah, you're going to have to throw in a couple of those killer cables to sinch the deal. Feast your eyes on this, your products name and tag line could be on this;
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • cstmar01
    cstmar01 Posts: 4,424
    edited April 2013
    Oh he'll just tell you your motorcycle racing isn't "high end" enough for him. I was told I wasn't an important enough person for him ever to meet. It's just sad to see Patrick have to go on sites like ours to try and get people to buy his crap. And if it really, for sure isn't Patrick, then we just found the reason as to why the world is doomed.
  • cheezy
    cheezy Posts: 148
    edited April 2013
    Jhayman wrote: »
    I am invincible and undefeatable. :lol:
    David R wrote: »
    I paid a lot of money on these White Night Power cables. But I have absolutely no regrets. I feel guilty I didn't pay enough. If I had more money I want to pay more money. The performance on sound is that good.
    If you haven't seen this, here is one of Patrick's $200,000 Grim Reaper power cable:
    https://www.youtube.com/watch?v=2bCnJViT1MA
    This one is a $1,000,000 Adria power cable. No introductory price on that one. The performance price is $2 mil.
    https://www.youtube.com/watch?v=kXYTeHv16d0
    Don't know if Patrick has the iPod cable for this, but you can run one of Patrick's power cables, such as HyperSpace, White Night, Blue Night, White Beach, or the new Rain Power 3m and add a powerstrip for your iPod. And if you are using the active speakers, get a pair of White Night power 2M cables for your speakers and connect directly from wall outlet to the speakers.
    Geoff4rfc wrote: »
    Good post and good question. I don't have enough money to sponsor you. By the way I'm not Patrick and I don't sell these cables. I'm sure Patrick could / should be able to help you with that. Send your motorbike suit to him. He should be able to add a logo Coconut-Audio for you. He had engraved my name on a $50,000 White Night Power Distributor for me which has gone lost now.
    In the White Night Power 5M package he sent me, it included the following items:
    - 2 x SeaShell BlackRain
    - 1 x Proximity Night Stone
    - 1 x Miracle Ball
    - 1 x GroundHanger Silver BlackHole
    - 7 x Coconut-Audio Protein Bars (I ate one, so I have 6 left)
    I thanked Patrick to death. Those items were given to me as gift.
    Pic of GroundHanger Silver Blackhole
    2x SeaShell BlackRain left, Miracle Ball center, Proximity Night Stone right.
    Got myself a motherboard mounting plate to setup my PC as a workbench and got rid of the huge LianLi case.
    I gotta ask Patrick if I placed the Miracle Ball correctly. That black thing in the back is the Blackhole GroundHanger.
    That's inside the Wine Storage cabinet in the upper shelf. It's placed there as my Wireworld Oasis RCA cables are too short. They can reach to speakers now.
    :lol:
  • ken brydson
    edited April 2013
    ZLTFUL wrote: »
    Can you share with us which prescription anti-psychotics you are on?
    I want to know because as effed up as the **** you post is, they have to be some quality drugs to make you hallucinate this much.
    There's coke all over the carpet in a couple of the pic's. There's your answer.
    F1nut Posts: 51,722
    edited April 2013
    Promise?
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited April 2013
    :lol:
    Promise?
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • PolkieMan
    edited April 2013
    Promise?
    Need some help, wait I have to order some MonoPrice speaker wire be right back. :smile:
  • decal
    decal Posts: 3,205
    edited April 2013
    Drenis wrote: »
    Then why do you keep reading and commenting about it?
  • Drenis
    Drenis Posts: 2,871
    edited April 2013
    decal wrote: »
    Why are you so interested in what I say? I didn't know you two were best friends.
  • cheezy
    cheezy Posts: 148
    edited April 2013
    Promise?
    Yes hon.
    decal wrote: »
    Drenis loves my thread I think. He is giggling and laughing behind the computer. icon7.png
    ZLTFUL, I am clean. I have no criminal background. I don't use any drugs and alcohol. The last time I had a glass of red wine was 5 years ago. I don't even drink wine cooler....
    I consume water, Japanese green tea, and healthy nutritious foods (fruits and vegetables). I can think better, see better, balance better, and hear better.
    In addition to this, I am not Patrick. I am not Swedish. I live in the states.
    Patrick confirmed that I did place the Miracle Ball in my system (see pic above) correctly. As you can see it is resting against the sound card. The blackhole ground hanger is hung on one of the unused 3.5mm connectors.
    I think I need to get rid of the Wireworld Oasis RCA cables. They hampered my sound. The Terra-6 sounds better. Later on I'm gonna pickup a pair of White Night 1.5m RCA from Patrick. I am broke right now and don't want to charge. The last purchase I made (White Night 5M cable) was paid cash. Anyone want to donate me some money? I need about $700.
    cheezie
