Dual Subs vs Single w/ dual opposing woofers
snake1
snake1 Posts: 567
edited April 2013 in Speakers
Another wonder question. I know the stuff about how having dual subs is a good route to go for several good reasons, but would you get a similar result with a single enclosure sub with dual woofers (ex. psw1200 or psw1000??) Any ideas??
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
Post edited by snake1 on
  • Conradicles
    Conradicles Posts: 6,396
    edited April 2013
    Not a similar result.
    It is not a bad idea if it is designed properly.
  • rpf65
    rpf65 Posts: 2,127
    edited April 2013
    If you buy a sub that uses 2 subs in one enclosure by any manufacturer, you will be buying whatever the specs say. If you use 2 different subs, each with one sub in the enclosure, and stack them on top of one another, you will get somewhere around a 6 dB gain from this configuration. Not a hard and fast rule, but usually pretty close.
    Even though there are 2 woofers in a single enclosure, it is still one sub.
  • chris23120
    chris23120 Posts: 95
    edited April 2013
    In my opinion Dual Opposing Drivers do a much better job filling my room than most of the single subs I have put in the same location. I also like that they don't move around. My experience is with the PSW1000 and PSW650 (1200's are quite rare but I plan to get one to mess around with at some point) When you have a sub firing off in 3 directions, especially if its corner loaded it can definitely make it an easier job to even out the bass response in a given room with only 1 sub. Having said that, if moneys not an object I would always go for multiple subs. I currently run 3 at most times. two Micropro4000 in my entertainment center firing at the listening position, and 1 modified PSW1000 down the right wall about 6' from my towers. That gives me a nice even sound across the room, with tremendous headroom without working anything very hard. My room is large, with a vaulted ceiling to my game room, open to the kitchen/breakfast nook, and with a 8' doorway to a two story foyer. In my upstairs tv room 16x12x8 I can get away with 1 correctly placed PSW.
    Samsung UN55C6500 55" LED
    Onkyo TX-NR3007
    Polk Audio RT5000
    -RT3000 front
    -CS1000 center
    -FX1000 dipole
    Polk Audio PSW1000 5.1 sub
    Polk Audio microPRO 4000 x2 5.2 subs:biggrin:
  • snake1
    snake1 Posts: 567
    edited April 2013
    chris23120 wrote: »
    Do auto calibration programs like audyssey work better with the dual sub setup as well? I've read that my 809 would better calibrate subs if there were more than one.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • snake1
    snake1 Posts: 567
    edited April 2013
    I meant with the dual sub single enclosure.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • snake1
    snake1 Posts: 567
    edited April 2013
    Sigh, sorry guys I can't type clearly today for some reason.
    Chris23120,
    What I meant to ask was does the dual woofer sub autocalibrate better with audyssey than a single woofer sub? I know a dual sub setup is supposed to calibrate better. Have you tested this yet?
    ps I wish there was a way to delete my posts that make no sense!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • zingo
    zingo Posts: 11,258
    edited April 2013
    Dual subs can help with room peaks and nulls, a single sub with multiple woofers can provide higher output and lower distortion than a single woofer.
  • chris23120
    edited April 2013
    I'm not really sure, I would have to test. Some subs, like the micropros have there own calibration so after you run that the audyssey doesn't seem to do as much.... I do think the latest auto calibrators are great. When I upgraded from my 10year old Onkyo to my current one it was a huge upgrade in my sound quality... I wouldn't worry about deleting posts, helps you get your post count up... I need to work on mine so I can start trolling the classified ad section....
    snake1 wrote: »
    Chris23120,
    Onkyo TX-NR3007
    Polk Audio RT5000
    -RT3000 front
    -CS1000 center
    -FX1000 dipole
  • Geoff4rfc
    Geoff4rfc Posts: 3,003
    edited April 2013
    snake1 wrote: »
    Chris23120,
    The two single driver subs I had before my current ones were crap subs to begin with. My 807 set them up the best they could be but I was always cranking them up trying to get more out of them than what they were capable of, so they never sounded very good.
    I upgraded to the Epik Empire, dual driver enclosed sub. The 807 set it up great. I got a second one and the 807 set them both up great.
    Regardless of a single driver or dual driver sub, like rfp65 said, it's still just one sub. And as others have mentioned, the second sub smooths out the bass response in your room.
