De-oxit for dummies
EndersShadow
EndersShadow Posts: 17,749
edited April 2013 in Electronics
So the HK Citation I got needed some cleaning. I cleaned the faceplate and knobs themselves today. I want to de-oxit where I can just so I know its super clean, and it cant hurt.
But with that said I have know idea where I need to spray the De-Oxit.... So I took some pics to get some help from the folks here....
Do I spray at the locations for the knobs at color one, or color two...
I am 99% sure I cant spray the EQ knobs given the warning I found above them... but looking again it appears I might only be able to spray the mode, function and speaker knobs.....
Do I spray the rear inputs at color one or color two
Post edited by EndersShadow on
  • brgman
    brgman Posts: 2,859
    edited April 2013
    what De Oxit are you using?
    Fader Lube woud be best for the pots i think.
    Red and Gold for the RCA's and connection spots.
    I’M OFFENDED!!!!
  • George Grand
    George Grand Posts: 12,256
    edited April 2013
    If color # 1 is white, that's the ticket in both photo sets. That is what needs to be cleaned. You can also spray directly into the RCA outputs on the back as you indicated with the red arrows.
    edited April 2013
    brgman wrote: »
    Haven't bought any lol, and didnt know there were multiple kinds.....
    Thanks George, thats exactly what I was looking to know. I will probably do that next weekend...
    mhardy6647 Posts: 35,516
    edited April 2013
  • boston1450
    boston1450 Posts: 7,758
    edited April 2013
    Great topic---good tips--- thanx
    good luck cleaning unit :)
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
