vinyl 180g?
soundfreak1
What are the diff types of vinly recordings ie: 180g ect and what is the diff between them. Thanks in advance.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
It's the weight of the vinyl used.Most of the old stuff was 120-140 g depending on who pressed it.
If you can recall the flimsy records that were "flexible" you will find the 180g to be heavy and stiff.Very stout.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I believe your right. I've even seen some 200g advertised, but don't own any.
My super crappy Crosley player that started me on this journey (not ashamed to admit it) had trouble with 180g.
My current player is fine of course, and I do like the added 'heft'2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
What kind of trouble?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
It would squeak with every rotation and the speed was inconsistent (think a car running out of gas...or a student driver braking and hitting the gas).
Regular albums played fine for my setup at the time.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
I guess the extra 40 or so grams dragged it down.Interesting.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Any diff in sound quality? I remember being able to order " master " records ( having to do with 1st press off master tape and much better sounding) i guess simular to the diff between red book cd's and hdcd and sacd. Are they still available or diff grade of recordings???Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Going shopping for some vinyl today is there any diff in sound??? Ib the diff weights in vinyl??? Any suggustions on type??Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
soundfreak1 wrote: »Going shopping for some vinyl today is there any diff in sound??? Ib the diff weights in vinyl??? Any suggustions on type??
Some say 180 and 200g are better.Some say it doesn't matter.
Personally i love the heavier vinyl and think it's better all around.YMMVMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
The weight of the vinyl is only one factor affecting the sound quality of the record. Certainly the heavier the vinyl, the less resonance you get within the record itself, therefore fewer vibrations making their way to the needle and muddying the sound. But a good clamp or weight can do a lot to better couple the record to the platter and remove a lot of that resonance. The heavier vinyl will also be much more resistant to warping.
But at the end of the day, a quality pressing of a quality recording wins every time, regardless of the weight of the vinyl. I've got albums from the 70's and 80's where the vinyl is quite light but the sound is outstanding, and I've got 180g "new" vinyl that has a lot of background pops and clicks.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
Just got back to the house with the M97xE mounted in its shell, table set up, seven new discs to spin! Im going in now.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Fully agree with this post, which is what I've experienced as well.The weight of the vinyl is only one factor affecting the sound quality of the record. Certainly the heavier the vinyl, the less resonance you get within the record itself, therefore fewer vibrations making their way to the needle and muddying the sound. But a good clamp or weight can do a lot to better couple the record to the platter and remove a lot of that resonance. The heavier vinyl will also be much more resistant to warping.
But at the end of the day, a quality pressing of a quality recording wins every time, regardless of the weight of the vinyl. I've got albums from the 70's and 80's where the vinyl is quite light but the sound is outstanding, and I've got 180g "new" vinyl that has a lot of background pops and clicks.Jay
soundfreak1 wrote: »Just got back to the house with the M97xE mounted in its shell, table set up, seven new discs to spin! Im going in now.
I suspect you will be very happy with that Shure. Remember, like anything else, it takes a cartridge some time to break in and open open up. Make sure you play it for about 50 hours before deciding if you're happy with it, but I'm sure you will be.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
You can stick a fork in my a** im well done! Alan parsons sounds great, hiroshima is astounding. So far so good!!Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Told you :cheesygrin:
Eventually you may wish to upgrade, but in the meanwhile start saving up for a cleaning machine. Cleaning your vinyl will give you a bigger boost in sound quality than any better cartridge will at this point. Enjoy!Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
HELL im already looking at tt's LOL and i did look at a "clean spin" today for 124.00. This is gunna cost!Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
I do know that people like the spin clean, and I've never used it so I can't really give you my impression of it. However, as an owner of a VPI, I cannot see how any mechanism can clean a record as well as one with a vacuum. And they are expensive. But if you're going to commit to vinyl for good, and you're going to start building a collection, when you consider the cost of the machine spread across your entire collection it's really not that much. The 16.5 retails for $600 (it can be bought for less....). Now that I have 300 records, when I consider the cost of the machine as $2 per record it doesn't seem like so much and easily is worth it.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
The $2 per albem isnt a problem the 600.00 is a mf'er.LOLMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
HELL thats more (600.) than i have in any one piece of equip. I own. To wash records? Damn for 20.00 i can get 2 prepubisent teenage girls in bikini's to hand wash them as i watch. Oops did i say that outloud?Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Check out how much the VPI Typhoon sells for :eek:Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
" moven too fast for the kid " deffinitly not that far in yet! Im not exactly beating them on a rock but not up to a couple grand for a washer aint gonna happen.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
I'm with you. By far the most popular vacuum machines are the 16.5 and the Nitty Gritty that's also in the same price range, don't remember the model. I've seen the 16.5 used sell for $350.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
That might happen. In the future.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Not trying to push you to do it now. Like I said, start saving, that's all I'm trying to tell you. Only point I'm trying to make is that the cleaning machine should be your next point of investment, since you've got a great starter cartridge that can take you a long way.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
You make a valid arguement. I will have to look out for one at the thrift store or sell something. Ive spent a fair amount of late!and i am stairing into an abiss called vinyl! God help me!Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
We don't call it a rabbit hole for nothing!Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
I have KAB ev1 that is a bit more affordable and does a great job. Add a hand steam cleaner to the mix and it is amazing.
http://www.kabusa.com/frameset.htm?/rcleaner.htmI got static in my head
The reflected sound of everything -
I own a VPI 16.5 and a Spin Clean. For entry level use the Spin clean does a great job.
Now, use it in conjuction with a VPI 16.5 and you have a real winning combo.
I like the fact that you can let areas of a record "soak" in cleaning solution in the Spin Clean. I have had some nasty dirt that was really stuck on some old records found in a garage sale. The Spin Clean "soak" overnight removes some real stubborn deposits of sticky **** with trapped dirt that the VPI could not touch.
Clean with Spin Clean, let dry, clean, vacuum, rinse, vacuum with the VPI. It's worth the work! Even some new vinyl sounded better after a thorough cleaning.Carl -
That may be a deal on the ev1.thanks for the tipMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Nspindel is right about some albums from the 70's and 80's sound better than the 180, 200 gr albums, but its individual. A lot of the 180, 200 gr albums sound really good, but I've bought some that sound like azz. I frequent a used record store a lot that has tons and tons of well-cared-for vinyl for very reasonable prices, often $3-$8, although collector albums can be astronomically priced. As an added bonus, they can sometimes inform me about things, such as which smaller labels were known for consistently high sound quality. That doesn't go so much for rock, but often it does for blues and other genres. George Grand also has lots of good quality records on the For Sale forum reasonably priced and best of all its for a charitable cause. When I got back into vinyl I hated getting up and flipping the record every twenty minutes, but now its not a big deal at all, I kind of like dropping the needle on the grooves and I really like the warmth of the vinyl sound.
Ya dromunds i can (for now) use the tt for criticle listening and the cd for just everyday music .and when im lazy.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
