Dual Subs vs Single w/ dual opposing woofers
snake1
snake1 Posts: 567
edited April 2013 in Speakers
Another wonder question. I know the stuff about how having dual subs is a good route to go for several good reasons, but would you get a similar result with a single enclosure sub with dual woofers (ex. psw1200 or psw1000??) Any ideas??
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
Post edited by snake1 on
  • Conradicles
    Conradicles Posts: 6,343
    edited April 2013
    Not a similar result.
    It is not a bad idea if it is designed properly.
  • rpf65
    rpf65 Posts: 2,127
    edited April 2013
    If you buy a sub that uses 2 subs in one enclosure by any manufacturer, you will be buying whatever the specs say. If you use 2 different subs, each with one sub in the enclosure, and stack them on top of one another, you will get somewhere around a 6 dB gain from this configuration. Not a hard and fast rule, but usually pretty close.
    Even though there are 2 woofers in a single enclosure, it is still one sub.
  • chris23120
    chris23120 Posts: 95
    edited April 2013
    In my opinion Dual Opposing Drivers do a much better job filling my room than most of the single subs I have put in the same location. I also like that they don't move around. My experience is with the PSW1000 and PSW650 (1200's are quite rare but I plan to get one to mess around with at some point) When you have a sub firing off in 3 directions, especially if its corner loaded it can definitely make it an easier job to even out the bass response in a given room with only 1 sub. Having said that, if moneys not an object I would always go for multiple subs. I currently run 3 at most times. two Micropro4000 in my entertainment center firing at the listening position, and 1 modified PSW1000 down the right wall about 6' from my towers. That gives me a nice even sound across the room, with tremendous headroom without working anything very hard. My room is large, with a vaulted ceiling to my game room, open to the kitchen/breakfast nook, and with a 8' doorway to a two story foyer. In my upstairs tv room 16x12x8 I can get away with 1 correctly placed PSW.
    Samsung UN55C6500 55" LED
    Onkyo TX-NR3007
    Polk Audio RT5000
    -RT3000 front
    -CS1000 center
    -FX1000 dipole
    Polk Audio PSW1000 5.1 sub
    Polk Audio microPRO 4000 x2 5.2 subs:biggrin:
  • snake1
    snake1 Posts: 567
    edited April 2013
    chris23120 wrote: »
    Do auto calibration programs like audyssey work better with the dual sub setup as well? I've read that my 809 would better calibrate subs if there were more than one.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • snake1
    snake1 Posts: 567
    edited April 2013
    I meant with the dual sub single enclosure.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • snake1
    snake1 Posts: 567
    edited April 2013
    Sigh, sorry guys I can't type clearly today for some reason.
    Chris23120,
    What I meant to ask was does the dual woofer sub autocalibrate better with audyssey than a single woofer sub? I know a dual sub setup is supposed to calibrate better. Have you tested this yet?
    ps I wish there was a way to delete my posts that make no sense!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • zingo
    zingo Posts: 11,258
    edited April 2013
    Dual subs can help with room peaks and nulls, a single sub with multiple woofers can provide higher output and lower distortion than a single woofer.
  • chris23120
    edited April 2013
    I'm not really sure, I would have to test. Some subs, like the micropros have there own calibration so after you run that the audyssey doesn't seem to do as much.... I do think the latest auto calibrators are great. When I upgraded from my 10year old Onkyo to my current one it was a huge upgrade in my sound quality... I wouldn't worry about deleting posts, helps you get your post count up... I need to work on mine so I can start trolling the classified ad section....
    snake1 wrote: »
    Chris23120,
    Onkyo TX-NR3007
    Polk Audio RT5000
    -RT3000 front
    -CS1000 center
    -FX1000 dipole
  • Geoff4rfc
    Geoff4rfc Posts: 2,845
    edited April 2013
    snake1 wrote: »
    Chris23120,
    The two single driver subs I had before my current ones were crap subs to begin with. My 807 set them up the best they could be but I was always cranking them up trying to get more out of them than what they were capable of, so they never sounded very good.
    I upgraded to the Epik Empire, dual driver enclosed sub. The 807 set it up great. I got a second one and the 807 set them both up great.
    Regardless of a single driver or dual driver sub, like rfp65 said, it's still just one sub. And as others have mentioned, the second sub smooths out the bass response in your room.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
