New rack for the electronics
BlueFox
BlueFox Posts: 15,251
edited April 2013 in Electronics
Over the last few years I have upgraded the components, cables, and power of my two channel system, but I have been using a TV/component rack that I bought at Macy’s in the late 80s. It had shelves on the left, a space for 27inch TV on the right, with drawers and a storage space on the bottom.
While it served its purpose, I did have to remove the back to allow better airflow, and to allow the power conditioner to use a shelf on the right. Another problem is that it is made of that fake wood stuff. While heavy, it really did not do a good job of absorbing vibration. Instead, it seemed to transmit vibrations into the gear. One reason I suspect is because it is closed on the sides. This serves no useful purpose, and is just more surface area exposed to sound waves, which results in more vibration. I think the vibration aspect of this rack is one reason why the brass footers under all my gear make such a big difference.
Anyway, I finally broke down and bought a Mapleshade Samson v3 four shelf rack with a rosewood finish. One shelf is four inches thick, and the other 3 are two inches thick. While I expected it to be heavy, this thing weighs almost 400 pounds! Believe me, it was a beast to assemble by myself. I was exhausted yesterday evening after finishing it.
I built it like a skyscraper, one floor at a time. I’m glad I planned on the 4 inch shelf being on the bottom because I could not lift it. I walked it inside from the garage, laid it on its side, inserted the 48 inch solid steel rods, and tilted it up. I had to get it into its final position before tilting it since once it is upright, it will not move due to the brass carpet piercing footers on the bottom. Adding the other shelves was easier, but really is a two person job. There is little tolerance in the holes for the rods so the shelf has to be level and come down equally on all 6 rods. I held the shelf on my extended arms on either side of the center holes, and lowered them onto the rack. Due to the little tolerance if it got just the slightest bit off from being level it would jam, and I would start cursing. I can’t print what I said since that would close this thread.
Finally, everything was together, and I have to say it looks great compared to the old rack. It is solid as a rock, and it is hard to detect any vibrations on the shelves. All I had to do on the previous rack was place my hand on it and I could feel vibrations. If there are vibrations now they are hard to detect. Also, now that the sides are open the sound appears more open and engaging with a much clearer focus of instruments in the sound stage. I really hoped this would occur, and it appears to be so. I don’t think I am doing a placebo effect here. It really is more open and precise.
While the overall height is lower than the previous rack, there is more room between shelves for the gear. This really helps the amps which get hotter than Hades. The drawback is it is harder to do cable management behind it since there is no moving the rack to get back there, but I did do a reasonable job of at least getting signal and speaker cables to cross the power cables at 90 degrees.
I only have two minor complaints, and both will soon be resolved. First is that four of the brass support/locking rings would not thread onto the rods. Replacements are on the way, and next week I need to remove the top shelf, and add the missing pieces. Second issue is there is a lingering odor from the rosewood stain. This is already diminishing and should soon be gone.
After one day I am really happy with this rack. It looks much better, and more important, it sounds great. I think I will order a 3 shelf version for the HT, but with only two inch shelves and 36 inch rods. I feel my entry level system just moved up a notch. Now it is time to do a pre-amp and amp upgrade to compliment the rack. It never ends.
Gear:
Amps (2) - Cambridge Audio 840W, 800w/ch at 4 ohm
Preamp - Cambridge Audio 840E
SACD - Sony XA-5400ES
Digital source - Bryston BDP1 digital file player
DAC - Bryston BDA1
Power conditioner - Shunyata Triton
Speakers:
Aerial Acoustic 7T - 4 ohm
Cables:
MIT S1.3 Shotgun XLR interconnects
Shunyata Anaconda Ztron speaker cables
Shunyata Python Ztron digital cable
Shunyata Python Ztron 20 amp power cable for AC input to the Triton
Shunyata Python CX 20 amp power cables (2) for amps
Shunyata Cobra Ztron power cables for pre, SACD, digital source, and DAC.
AC:
20 amp dedicated line
Shunyata SR71 AC duplex.
Miscellaneous:
Acoustic Revive RR77
Mapleshade speaker stands - 4", rosewood, brass carpet piercing footers.
Mapleshade Micropoint brass footers
Audio Advisor brass Sonic Saucers for footers
Post edited by BlueFox on
  • pglbook
    pglbook Posts: 2,260
    edited April 2013
    That is a thing of beauty! Congratulations!
  • Conradicles
    Conradicles Posts: 6,343
    edited April 2013
    Looks like an upgrade for sure!
  • Dominion
    Dominion Posts: 69
    edited April 2013
  • BlueFox
    edited April 2013
    I forgot to mention if anyone wants the old rack then show up with a 12 pack and it is yours. I'll throw in a pair of SDA 2 speakers also. I am running out of room.
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited April 2013
    Very nice setup,I like the rosewood color.
    Enjoy
    gudnoyez Posts: 8,161
    edited April 2013
    BlueFox wrote: »
    Looks awesome nice stuff, I will be down in San Diego visiting my mom in a few months. I would head north and bring a case of your choice for those SDA 2's. I would have to pass on the old school entertainment center as I have one similiar to that one.
    F1nut Posts: 51,770
    edited April 2013
    It's not the stain, it's the clear coat gassing off.
  • BlueFox
    edited April 2013
    gudnoyez wrote: »
    It's a package deal. The SDAs are a bonus for taking the rack. :biggrin:
  • BlueFox
    edited April 2013
    Great. Between me gassing off and the rack gassing off I have my own WMDs here.
  • thsmith
    thsmith Posts: 6,082
    edited April 2013
    Beautilful rack !
    F1nut Posts: 51,770
    edited April 2013
    BlueFox wrote: »
    LOL...
    Your new rack is a big improvement, congrats.
  • FTGV
    FTGV Posts: 3,650
    edited April 2013
    Nice rig and rack.
  • Jhayman
    Jhayman Posts: 1,548
    edited April 2013
    Very nice looking, I like how it's all open and thick shelves..
    Very cool
  • jumpindick
    jumpindick Posts: 428
    edited April 2013
    Nice one.. It sure does look pretty heavy. Enjoy.
  • marvda1
    marvda1 Posts: 4,945
    edited April 2013
    looks like you're trying to make mapleshade rich:biggrin: looks great.
    Puritan PSM156
  • BlueFox
    edited April 2013
    marvda1 wrote: »
    LOL. So true, the same for Shunyata. That is what happens when a vendor offers a superior product at a lower price point than the competition.
  • ratster
    ratster Posts: 324
    edited April 2013
    Very nice.
    Entry level? That's funny.
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Clear Day dbl.shotgun
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
    Clear day dbl shotgun
  • Drenis
    Drenis Posts: 2,871
    edited April 2013
    Looks real nice.
  • Ern Dog
    Ern Dog Posts: 2,237
    edited April 2013
    I like that rack design, lots of space. It looks clean and tidy too. Cool looking cat in the last pic.
  • Thorton
    Thorton Posts: 1,324
    edited April 2013
    Very nice rack and nice set-up Blue! Enjoy.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2013
    Very nice, great setup! Enjoy.
  • hochpt21
    hochpt21 Posts: 5,423
    edited April 2013
    Whew! That's pretty.
    A million times better than what you had.
  • BlueFox
    edited April 2013
    Thanks everyone. There doesn't seem to be much love for the Macy's Home Entertainment rack. I guess I had it for so long I never really looked at it anymore. However, I can't stop looking at the new rack. I am really pleased with this purchase, plus it is easy to show off to guests. The break-in process is moving along, and soon I will have a few hundred hours on it. :smile:
  • BlueFox
    edited April 2013
    Just a quick follow up on these items. I received the 4 new brass nuts yesterday, and installed them. Also, the odor has dissipated and is no longer noticeable. The drawback to it is I just ordered the latest Bryston BDA2 DAC to improve the sound from the new rack. :lol:
  • michael1947
    michael1947 Posts: 775
    edited April 2013
    Now that's a nice rack.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited April 2013
    Very nice, love the look and very functional, good choice. A new rack is also on my "to do list"
  • headrott
    headrott Posts: 5,496
    edited April 2013
    Great rack there BlueFox!
