Do you need a sub, for SDA 1C's for 2 channel music??
124
    heiney9 Posts: 25,408
    edited April 2013
    Agreed, with the following caveat: It's not about "pure watts" (quantity) or "quality watts;" its about quantity AND quality watts. Playing music with a wide dynamic range and fast transients requires speed and plenty of "headroom" in the amp, and the "watts" have to be "quality" watts IMHO.
    Headroom and reproducing dynamic range, fast transients and speed is not about watts anymore than making a great handling car is all about top speed. People need to stop equating the above with how many watts an amp is rated at. It's a small part of the entire picture..........not "THE" part of the picture. Until one learns that, they end up chasing their tail.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited April 2013
    heiney9 wrote: »
    I think we are in what I like to refer to as "screaming agreement!" :smile:
    But, I do not pretend to be an expert on this or any other issue about 2 channel equipment! Maybe, I'm missing something.
  • motorstereo
    motorstereo Posts: 2,316
    edited April 2013
    Toolfan66 wrote: »
    Listen the cost of daisy chaining a sub into the mix is the deal breaker for me in even if I wanted to try it.. I don't see where the cost of said $1000+ subs, then add the cost of some good cables, and what other goodies one might need to make it happen..
    And I have yet to come across a two channel pre with sub outs..
    Again the daisy chaining kills it for me..
    The cost I can certainly understand being a deal breaker. But should you find a deal on a quality sub you don't need to go spendy on the cables because of the limited bandwith the sub's covering. Also you don't need a dedicated sub line out like on a ht receiver. Just a pre with dual preouts which are very common. There's no "daisy chaining" involved here.
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited April 2013
    Analog headroom definition:
    head•room (ˈhɛdˌrum, -ˌrʊm)
    n.
    3. the additional power output capability of an amplifier when producing short-term peak signals.
    Looks like both you guys are correct.
    Headroom is definitely wattage (but usually rated as an equivalent db), but when analyzed as a percent of rated RMS signal it can be small or very large. A 3 watt tube amp with 3db of headroom will be capable of 6 watt transients while a 300 watt solid sate amp with 3db of headroom will be capable of 600 watt transients. But these are transients and not described as the continuous wattage, which may be what H9 is saying (I am not sure as I can not speak for him). But headroom is definitely power (wattage) related.
  • Moose68Bash
    edited April 2013
    n.
    Thanks, Mr. Bubbles,
    This is a clear explanation of what I thought was the meaning and importance of "headroom" from an amplifier.
  • ALL212
    ALL212 Posts: 1,650
    edited April 2013
    TennMan wrote: »
    This topic about subs is getting quite complicated.
    I need to get up to speed on how many different kinds of watts there are. So far I see there are "pure" watts and "quality" watts for sure. It seems there must be some kind of watts called "headroom" watts too. I know there are "light bulb" watts because I've seen that wrote on light bulbs. None of those watts are listed on the spec. sheet for my amplifier. It just says "Watts" so I have no idea what kind of watts I have.
    When I search the Internet for watts I keep running across this Lawman named Ohm who has formulas for making watts. There is just no telling what kind of watts that guy is making. What we need to do is come up with some kind of standard rating system for watts so when we look at the label on our amplifiers we will know what kind of watts we are buying. I live on Watts Bar lake. If I could find that Bar I'll bet the bartender or some of the regular patrons there could tell me all about watts. I doubt they will know much about subs. I'll let you know what I can find out but I don't think subs are allowed on Watts Bar lake. It's not deep enough for a sub.
    This one wins...hands down. The rest of you just piss and moan on! :cheesygrin:
    I see no reason to debate this further - you either like a sub with your system or you don't. I sincerely doubt this thread is going to set someone "right" or convince them that they are "wrong" from either camp.
    Aaron
    Enabler Extraordinaire
  • nspindel
    nspindel Posts: 5,343
    edited April 2013
    ALL212 wrote: »
    This thread? Do any threads ever change people's minds around here? :cheesygrin:
  • ALL212
    ALL212 Posts: 1,650
    edited April 2013
    No...but darn it...my watts are cleaner than yours. I can't prove it, I've never heard your system nor have I ever heard any of the components in your system but...mine are bigger, better, faster, deeper, higher, clearer and just plain cooler. (period)
    :evil:
    Aaron
  • Mr. Bubbles
    edited April 2013
    But mine go to "11"!
  • westmassguy
    westmassguy Posts: 6,850
    edited April 2013
    Yeah well, I just changed the knobs and little plates that have numbers on them on my two Subs. Mine go to 20 now, and I didn't even have to change any of those funny looking electrical widgets inside. So there!
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • SDA1C
    SDA1C Posts: 2,072
    edited April 2013
    The hardest part to come to grips with is that adding a sub/subs is NOT...I repeat is NOT all about simply adding more bass. Re-read my post #83 which explains just a few of the benefits on the whole picture. For some reason the minute you mention a sub you get the same old same old ...I don't need more stinking bass, my speakers can rattle the walls already. Well that's great but has nothing to do with adding a sub. Funny how guys will talk about the musical revelation they experienced when they swapped out some cables yet can't get their heads around the notion that a sub is a huge plus for any speaker.
    Interesting observation. I would like to hear rebuttal on this one!
    Too much **** to list....
  • Moose68Bash
    edited April 2013
    nspindel wrote: »
    Yes, they do! :razz:
    My mind (such as it is!) has been changed by many threads on this forum, and it has cost me considerable money!
    F1nut Posts: 51,694
    edited April 2013
    SDA1C wrote: »
    What Phil fails to understand is that not every speaker requires a sub and therefore will not benefit the way his obviously did because not every speaker is designed like his.
  • ALL212
    ALL212 Posts: 1,650
    edited April 2013
    Somebody define "quality watts" please. I'm having difficulty getting a grip on that phrase.
    As defined - everywhere:
    One watt is the rate at which work is done when one ampere (A) of current flows through an electrical potential difference of one volt (V).
    Since watts are a measure of work...and you reference your amps...WTF? Are you lifting them?
    Sounds more and more like some of our less favorable magazines floating around in here. Are we just makin' stuff up so it sounds cool or are we so confused we don't even know what these electrical terms refer to? I've yet to see an amp rated based on anything other than a number.
    So which number = "Quality"? :wink:
    Aaron
    F1nut Posts: 51,694
    edited April 2013
    That one is easy, you know it when you hear it.
  • ALL212
    ALL212 Posts: 1,650
    edited April 2013
    Great...user defined. :cry:
    So as long as my ears "work" I have quality watts.
    Stereopile magazine must use these...
    Aaron
  • pearsall001
    pearsall001 Posts: 5,242
    edited April 2013
    No one is saying that a speaker requires a sub/subs...but merely that all speakers will benefit from the addition of one or two. When implemented correctly (it takes a lot of work & the sub must be of hi-quality, not a sub designed as a boom box for HT) the results are simply amazing. The whole music landscape is transformed. There just isn't a one box speaker that can do it all. Now that doesn't mean they can't sound good because they certainly can but if you want to maximize their performance, well you know the drill.
    Toolfan66 Posts: 17,994
    edited April 2013
    So what do you consider a high quality sub??
  • schwarcw
    schwarcw Posts: 7,358
    edited April 2013
    Both current and voltage are required to produce power (watts). That’s why both amps and voltage are important.
    From a variety of Internet sources:
    James Prescott Joule, not Georg Simon Ohm, who first discovered the mathematical relationship between power dissipation and current through a resistance. This discovery, published in 1841, followed the form of the last equation (P = I2R), and is properly known as Joule's Law. However, these power equations are so commonly associated with the Ohm's Law equations relating voltage, current, and resistance (E=IR ; I=E/R ; and R=E/I) that they are frequently credited to Ohm. The original E = IR equation can be manipulated to find any one of the three if the other two are known. The three possible forms of the equation are:
    (1) E = IR
    (2) R = E/I
    (3) I = E/R
    Example: If you measure the current going into an 8 ohm speaker, and find it to be 2.5A RMS, the voltage across the speaker can be found by multiplying the current by the resistance, or E = IR = 2.5A*8ohms = 20V.
    Example: If you have a resistor of unknown value, and you measure 10V across it with your voltmeter, and then put an ammeter in series with the resistor to measure the current, and find it to be 100mA, the unknown resistance value could then be found by dividing the voltage across the resistor by the current through it, or R = E/I = 10V/100mA = 100 ohms.
    Example: If you have a 100K resistor, and you measure 100V across it with your voltmeter, the current flowing through the resistor can be found by dividing the voltage across the resistor by the resistance, or I = 100V/100K = 1mA.
    The power equations
    A related equation is used to calculate power in a circuit: P = EI, where P = power (in watts), E = voltage (in volts), and I = current (in amps).
    Example: If you want to determine the output power of an amplifier, and measure 20V RMS across the load and 2.5A into the load, the power delivered by the amp to the load is: P = 20*2.5 = 50W.
    As with the Ohm's Law equations, this equation can also be rearranged to solve for the other two quantities to produce three possible equations as follows:
    (1) P = EI
    (2) E = P/I
    (3) I = P/E.
    Example: If you have an amplifier that puts out 100W into a load, and you measure 2.5A into the load, the voltage across the load can be calculated as E = P/I = 100W/2.5A = 40V.
    Example: If you have an amplifier that puts out 50W into a load, and you measure 20V across the load, the amplifier is putting out a current of I = 50W/20V = 2.5A.
    The power equation can also be combined with the first Ohm's law equation to derive a set of new equations. Since E = IR, you can substitute IR for E in the power equation to obtain:
    P = EI = (IR)*I, or P = I2R.
    You can also find P if you know only E and R by substituting I=E/R into the power equation to obtain:
    P = EI = E*(E/R), or P = E2/R.
    Example: What is the RMS voltage at the output of a 100W amplifier into a 16 ohm load? The answer can be found using equation (6): E = sqrt(PR) = sqrt(100W*16ohms) = 40V RMS.
    Example: An amplifier is connected to an 8 ohm load. The RMS voltage across it is measured using a DVM (digital volt meter) and found to be 15.5V right before clipping. How much undistorted power can the amplifier put out into an 8 ohm load? The answer can be found using equation (4): P = E2/R = 15.52/8 = 30 Watts.
    Example: How much current does a 100W amplifier put out into a 16 ohm load, an 8 ohm load, and a 4 ohm load? The answer can be found using equation (3). For the 16 ohm load, I = sqrt(P/R) = sqrt(100/16) = 2.5A For the 8 ohm load, I = sqrt(100/8) = 3.54A. For the 4 ohm load, I = sqrt(100/4) = 5A.
    Summary
    Ohm's Law is probably the single most important equation used in designing or analyzing a circuit. These equations are useful for calculating many parameters in a guitar amplifier, including output power, voltage drops across resistors, current through resistors, power ratings of resistors, and many other things.
    Carl
  • ALL212
    ALL212 Posts: 1,650
    edited April 2013
    Oh...now I get it. :sad:
    It's not the amp (select your favorite brand name) that has quality watts. The amperage has quality watts!
    So that's how it "works"...!! :smile:
    Aaron
    F1nut Posts: 51,694
    edited April 2013
    There's a lot of audio folks and a whole lot of speaker designers/companies that will vehemently disagree with that.
  • Mr. Bubbles
    edited April 2013
    ALL212 wrote: »
    Simply put a watt is a watt. period. What is meant by a quality watt (specifically to audio because I don't think a light bulb cares) is when there are little to no additional anomalies applied to the output signal as related to the input signal and also the ability for the amplifier to control the speakers. Per your definition and other electrical laws/ definitions a watt of power is just that a watt of power and the calculations used to determine that take nothing into account about distortion, S/N, damping factor, Whether the power rating is true RMS or for a split second if lightning strikes the power line outside, etc. Though a watt is a watt, there are definitely good quality amplifiers and poor quality amplifiers and many levels in between.
  • falconcry72
    falconcry72 Posts: 3,580
    edited April 2013
    I think one point that you're missing is HOW a sub gets integrated into a dedicated 2-channel system. In your system (using an AVR as a preamp) it is very easy to integrate a sub without losing fidelity because you can just set the AVR's internal crossover and you're done. In a DEDICATED, clean, simple 2-channel system, the only way to add a sub and "relieve" the speakers of all bass duty, is to ADD an external crossover. Introducing an external crossover to the mix is always detrimental to fidelity.
    Obviously if a 2-channel preamp has multiple outputs you can just add the sub that way, but then you don't get any of the benefits you describe by stripping low frequencies from the speakers. If you want to strip low frequencies from the speakers, you have to introduce a crossover of some kind, and it's always going to be a give and take on whether people want to accept the fidelity degradation that is inherent to an external crossover so that they can augment bass response.
    Again, there's no right answer. Different strokes.
  • nspindel
    edited April 2013
    It'll be a cold day in hell before I start stripping the low frequencies out of my SDA's. Just sayin'.
    edited April 2013
    nspindel wrote: »
    Love it!! LOL!!
  • Face
    Face Posts: 14,340
    edited April 2013
    The best placement for imaging, soundstage, is not always the same placement for the best bass response. Additional subs to smooth out bass response in the room can be a great thing, when done right. But getting it done right, can be far from simple. One has to account for delay(phase differences between mains and sub(s)), setting slope between mains and sub, level, etc... IMO, it works best between mains that are sealed due to their better impulse response and shallower roll off(12db opposed to 24db/octave). And to agree with Phil, it's not about additional bass, it's about better bass.
    Now that about designers and companies disagreeing, even Wilson Audio and Sonus Faber offer subs and will have someone come to your house to set up both. I've heard a few Sonus Faber and JL Audio setups dialed in by Sumiko and you wouldn't know there were separate subs in the room. In both cases the bass was phenomenal, clean and taut, without being overpowering or boomy.
    edited April 2013
    I love Sonus Faber!! I would like to hear that set-up..
  • motorstereo
    edited April 2013
    nspindel wrote: »
    Agreed; that ain't happening here either. But it'll also be an ice cold day downstairs when I stop supplementing my SDA's lowest frequencies.
    edited April 2013
    Watts never tell the final story about sound. A watt is a watt if you are just measuring its electrical properties. But watts don't mean squat beyond achieving SPL. Only the foolhardy judge sound quality and performance by rated wattage. There is far, far more to quality sound than watts.
  • GospelTruth
    GospelTruth Posts: 403
    edited April 2013
    Interesting article about this very topic. I'm sure everyone will have their varying opinions on this I'm sure. I'm a no sub guy myself for 2 channel, but it's a good read regardless.
    Subwoofers: A Brief Look at the Effectiveness of Using a Subwoofer in a Music System
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
