Martin Logan Motion 12 VS Polk RTi a7
tommyt21
tommyt21 Posts: 685
edited April 2013 in Speakers
The Motions just went on sale at Newegg for 299 a pop, I can get the Rti A7's for 399 a piece. I have been wanting the Rti A7's for awhile. I just bought a Pio SC-35 and do 90% home theater. Is the Rti A7 still the best choice for me?:confused:
Thanks in advance Polkies you guys Rock!!:cool:
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
    EndersShadow Posts: 17,753
    edited September 2011
    tommyt21 wrote: »
    Do you have the gear to run 4 ohm speakers properly? If not, decision made right there as the Martin Logal 12's are 4 ohm :smile:
  • tommyt21
    tommyt21 Posts: 685
    I'm confused because the detail page says their compatible. I believe my pio sc -35 can run 6ohms by changing the settings??
    Nominal Impedance4 Ohms. Compatible with 4, 6, or 8 Ohm rated amplifiers.
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • tommyt21
    tommyt21 Posts: 685
    when they give the width measurement on the rti a7 does it include the feet or is it just the cabinet?
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • polkfarmboy
    polkfarmboy Posts: 5,703
    Here's the deal
    Martin logans will run just fine with your pioneer sc35, sure they are rated at 4 ohms but the ice amps in your pioneer will be able to handle that load .The first gen of the folded motion tweeters(in the 12's) is half the size of the second generation so they require more juice to get them going and thats where the 4 ohm rating comes from so dont expect them to dip down to one ohm like the vista's and other ML's normally would
    The motion 12's is a difficult comparison for me because the tech is so different .The motion 12's have a dipole midrange driver on the cabinet under the folded motion tweeter so its going to make placing them difficult and harder to integrate into your room .I personally prefer the motion 12's to my polk rti8 but I have not heard the rti10's, rta7's but I would think they would have cleaner mids and equal the bass as rti8 and 10 should not differ that much
    If I was in your shoes I would consider this ...... If you get into motion 12 then your going to have to get a matching center and the best they have for the first gen of folded motion is the motion C .Its the same center almost as the motion 8 but it has a wooden cabinet that improves the bass .I dont think the motion 8 can equal the polk csi5 or csi a6 so and it costs more money so thats a very important factor to consider when building a HT rig because as you know they center channel is the king and determines the experience . ML has a new center channel out that costs $800 with the generation 2 folded motion tweeter thats double the size and although I only spent 10 mins in a demo with it its not that great for the cost as there is better out there
    ML has 3 surrounds channel options motion 2 ,4 both are weak sauce and the motion fx that retails at a whopping $800 so I would just use motion 10 towers at $200 online right now or $250 from amazon and bestbuy etc
    Bottom line, sure the motion 12's are cheap but its going to get expencive fast to build a whole system .Polk is going to give you way more performance for your money and they look way better
  • tommyt21
    tommyt21 Posts: 685
    Here's the deal
    Thats an Awsome reply. My curiousity started to getto me but your perspective seems to have solidified my quest for the Rti A7
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • B Run
    B Run Posts: 1,888
    I demoed some at best buy and honestly wasn't impressed. I'm sure they weren't properly setup though.
  • stangman67
    stangman67 Posts: 2,330
    I have heard the Motion 12's have some very strange sound characteristics. I wouldn't pick them.
    JR has rti 10's for 249 a pop. That is what I'd do in that price range
  • TommyT
    TommyT Posts: 8
    edited March 2013
    Any suggestions on additional speakers or amp?
  • fokakis1
    fokakis1 Posts: 36
    edited April 2013
    I have heard both and tho I won't say which was better sounding to me (subjective opinion), I will tell you that I had to sit very still while listening to the Motions as their sound changed dramatically as I moved even a few inches off axis.
    Full 8.2 with:
    Onkyo TX-NR818
    Emotiva XPA-3
    Audiosource Amp One/A
    Behringer EPQ2000 w/quietfan mod
    Panny BDP310
    3TB NAS
    Ethereal ESP601R
    Monster HTS 1650
    Epson HC-3020
    120" DIY 1.0 Gain Screen
    Polk Rti A9 fronts
    Polk Rti 6 surrounds
    Polk Rt/Fx rear surrounds
    Polk Rti 4 front heights
    (Phantom center):wink:
    SVS 12's x 2 (DIY passive):eek:
    ATS Acoustics DIY panels
    Harmony 650
    Nostalgia Electronics CCP-510 MovieTime Popcorn Cart
  • theshawn
    theshawn Posts: 70
    edited April 2013
    I just picked up two Motion 12's on Newegg for $230 each. Judging from most reviews I think it's a solid buy and something I'll like. Can't wait for them to arrive.
