Nad cassette decks with fast forward and rewind issues
kquail
Alot of people has helped me out on this forum , I just wanted to post something about NAD cassette decks to help others !
I recently purchased alot of so called NON working NAD cassette decks from ebay ! people are claiming fast forward and rewind does not work! when i get the decks in ,i find that the lube that nad used originally ,has hardened really bad and dried out causing the the posts that the cassette sits onto and drives the tape in the cassette, are real hard to move !
I got a light oil ,like for electric motors ,NOT WD40!!!!, and lubbed all the moving parts, and rewind and fast forward a cassette over and over again! lubbing it repeatidly! and the old lube loosens up and fast forward and rewind works like new again ! alot of people think the motor that opereates the fast forward and rewind is bad this is not the case ! the NAD uses 2 motors one to play, and one to fast forward and rewind
I hope this helps people with this issue
and thanks everyone who helped me with my issues
crank it till your ears bleed
thanks for sharing, good info2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
