Expidit album storage pics
hochpt21
hochpt21 Posts: 5,423
edited April 2013 in DIY, Mods & Tweaks
Hey all, I know there have been a few threads about album storage. I had previously used a two-square by four-square Expidit shelf from IKEA. I really like the look and function, so when we moved to our new house with a bigger living room, we bought a 4x4.
Now if you Google image 'expidit record storage' you can find some pretty nasty pics of these 4x4's coming apart and dumping albums. I don't think this is a common problem, but it obviously has happened.
So just to be on the safe side, I made some modifications to my shelf.
Here are the pics...
I spray painted some small "L" brackets to match the finish of the shelf and screwed them into the corners of the end shelves that are only otherwise supported by wooden dowels. (the middle shelves are supported by the verticle running boards)
Next, I screwed 1/4" MDF board to the back of the unit to provide additional support from coming apart (reference the images of how the shelf has failed in some cases)
Before I attached the MDF, I painted the side facing the shelves the same color as the wall so we still get the intended effect of the 'see-through' shelf.
And here are a couple pics of the finished project. Hope you enjoy!
Post edited by hochpt21 on
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited April 2013
    Well done! Doubt if you ever get any sag in the shelving, let alone completely falling apart.
    Envious of your number of albums, and the rack. Looks great!
  • thsmith
    thsmith Posts: 6,082
    edited April 2013
    Very nice, thank you for sharing.
    SCompRacer Posts: 9,112
    edited April 2013
    Good 'beef' job! I've seen book shelves fall apart in the same manner. A strong backboard is a big help. Like the wall color touch.
  • chumlie
    chumlie Posts: 8,658
    edited April 2013
    EndersShadow Posts: 17,704
    edited April 2013
    It looks quite nice I must say. Can't even tell there is a back!
    Only thing I personally might change if I were to do it is to put some L brackets along the corners along the edges instead of the backing and mostly because I have no clue what paint color the apartment complex used lol.
    That and if we moved I would have to repaint the backing.
  • hochpt21
    edited April 2013
    Thanks all!
    No sag in the shelves, that's for sure.
    Matching the paint was easy since we just had the living room painted. I didn't think it would turn out as good as it did, so I am happily surprised.
    I've already started cleaning more vinyl. Everthing on the top shelves is cleaned, and all those on the bottom are in the queue :eek:
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2013
    Looks great!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
