Bedroom Speakers
I am going to be putting some kind of speakers in the bedroom, and I am trying to figure out what direction I want to go. The room is small, 17 ft x 14 ft I would guess, vaulted ceiling. I imagine a 5.1 system would be a bit much. I was thinking I would go with 2 in ceiling speakers, a center and a sub, when a friend recommended a sound bar. I have no experience with them though. So, I was wondering if you guys could give some suggestions on which set up might be preferable for this type of room? To give a price range, I wanted to keep the speakers around $250 a piece. Thanks for any help you can provide. One other thing, this will be primarily for movie/ tv viewing.
Personally, I would go with a 3.1 system rather than a sound bar. I'll admit, a soundbar sounds better than your average tv speakers, and good ones sound better than many HTIB systems. I ran the RTI A1's, CSI A4, and A DSWPRO 440wi, and it blew away just about every soundbar or HITB system I ever heard. Of course many may disagree. Still for slightly more than $700 those speakers sounded good together.
I have a small Denon 40watt or so hooked to a flat screen in the bedroom with some small bookshelf 12in or so speakers and a powered narrow subwoofer tucked away..it sounds awesome--i also can lay and enjoy music. Doesnt take up much room and it fills the room with quality sound at affordable price. Easy hook up. It depends on what you really want & cost--if you get the right small bookshelf speakers you may get the big speaker sound also..Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Get a 5 pack of Blackstone TL3's with a sub and you will be good to go.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I have a pair of ADS L690 and small 8" Sony Sub using an Pionner Elite VSX-30 but is only for music.HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
I also have vaulted ceiling in my master bedroom, I've decided to add a simple 5.1 setup in there. R2000's fronts, CS350LS center & RT LS/FX rear. I plan on puting together a small surround for when I want to go to bed early and still feel like watching a movie. My main setup is in the living room, it's a 7.2 setup. Nothing crazy, just a RT5000 with a PSW1200 & PSW650.SRT Seismic System with dual PSW1200's
RT5000 x 2
RT2000p
CS400i
CS350-LS
LS F/X
PSW650
PSW1000 w/Dayton SPA1000
DSW MicroPro 4000
Adcom amps
Pioneer Elite SC-89
Pioneer PLX-1000 Turntable
PS4
XBOX One
MIT Interconnects
BJC -
I bet Polks in-wall stuff sounds good.
B&W CM9Classé Sigma
