Polk LS90 vs Paradigm Studio Monitor (original)
MiguelGuillardo
MiguelGuillardo Posts: 6
edited January 2014 in 2 Channel Audio
As the title states, I'm trying to decide between 2 sets of tower speakers. The Polk LS90's or the Paradigm Studio Monitor (original version with 2x8" woofers, tri-ampable). Both sets of towers are used, with the Polk towers being about a 1/3 of the price of the Paradigms. I will be using them in a small listening room for now, with plans for a larger listening room in the future. My listening room is treated with acoustical panels as well as carpeting, and sounds pretty good even with speakers that are too large for the current room's dimensions. The system will mainly be for music, 2 channel, and run off a rotation of gear (separates, vintage receivers, integrateds, AVRs).
I'm wondering what people's opinions are between these two speakers. The Paradigms seem very similar to the Studio 100 v1 and v2, which all seem to get good reviews. The downsides are that many comments recommend large listening rooms and high current amps (2-400w+). The Polks also get good reviews, and I've been able to listen to them quite a bit and I've been impressed with their sound. People also seem to recommend a couple hundred watts to power the Polks. My main amps now are 125-160wpc for the most part. Most of my amps should be fine with the speakers dipping down to 4ohms and even below for a short period. Listening would be done largely at low volume, with the occasional high volume listening session.
Let me know if there are any variables I've missed. TIA for your advice.
Post edited by MiguelGuillardo on
  • sucks2beme
    sucks2beme Posts: 5,691
    edited March 2013
    The Paradigms are a good HT/music speaker that is 8 ohm friendly.
    The LSI90's are a very good music speaker that is 4 ohms and is hard to drive with HT receivers.
    IF your amps are up to it, the LSI's are a good choice. I've owned the Paradigm studio 60's
    and found them to be pretty good, but had a hot upper bass. They could fill the room
    with 50 watts no problem. My son still has the studio 60's running on his HT set up and loves them.
  • MiguelGuillardo
    edited March 2013
    Thanks for your input. Just to clarify, they are LS90s, precursors to the LSI series of speakers
    http://www.polkaudio.com/products/ls90
  • ken brydson
    ken brydson Posts: 9,024
    edited March 2013
    sucks2beme wrote: »
    LS90's are 8 ohm. I love mine, great for music and HT.
  • MiguelGuillardo
    edited March 2013
    I'd agree the LS90s were great sounding speakers, I'm just trying to decide if the Paradigms will be a big enough increase in performance to warrant the large price difference. I have heard the Paradigm's tweeter can be harsh, although I've also read that about the tri-lam in the LS90s
  • ken brydson
    edited March 2013
    Never heard the Paradigms so I can't help you there. The tri lams do mellow with better cables, etc...
  • thsmith
    thsmith Posts: 6,082
    edited March 2013
    I am driving a pair of LS90s in my office with a 40wpc tube amp and sounds glorious. Updating the one cap and resistor in each speaker is worth doing. Oh yeah, spike them too.
  • sucks2beme
    edited March 2013
    Whoops. Space moment there. The older LS series were more amp friendly.
    I'd say buy the Polks and enjoy the savings. With the day I've been having I really
    didn't take to time to think about the Polk model. The Paradigms are certainly a fine speaker,
    but $$ vs $$$$ is the tie breaker. I can't believe I somehow confused ls vs. LSI models.
  • MiguelGuillardo
    edited March 2013
    sucks2beme wrote: »
    That echos my thoughts on the deal as well. It's possible the Paradigms are nicer speakers, but I don't know if they are worth the extra $
  • MiguelGuillardo
    edited April 2013
    Last question
    Would you pay $500 for the Paradigm's?
  • sucks2beme
    edited April 2013
    last question
    would you pay $500 for the paradigm's?
    yes!
  • gustavo70
    gustavo70 Posts: 3
    edited April 2013
    LS90' the best!!!
  • Jhayman
    Jhayman Posts: 1,548
    edited April 2013
    Yes.. Twice
    I'm driving Studio 100's right now and LOVE them..
    Last question
  • Goldenboy72206
    Goldenboy72206 Posts: 126
    edited April 2013
    i love the ls90
  • mopar paul
    mopar paul Posts: 277
    edited April 2013
    I've had both and prefer the sound of the Paradigms, just seem "cleaner" to me. I found that sometimes the ls90 seemed bloated.
  • thsmith
    edited April 2013
    mopar paul wrote: »
    LS90s if not positioned correctly can sound bloated.
  • MiguelGuillardo
    edited April 2013
    Thanks for the opinions everyone! Def helps to hear from an assortment of people
    mopar paul wrote: »
    I appreciate the input, especially from someone that has listened to both.
  • ken brydson
    edited April 2013
    I would never call the 90's bloated but to each their own... My description would be punchy bass, smooth mid's and crisp highs, especially after upgrading the c/o's. YMMV...
  • attym
    attym Posts: 33
    edited December 2013
    Do you know how many ohms the paradigm studio monitors are? What did you end up going with?
    I bought a pair of studio monitors and while they sound great (amazing bass and detail), I can help but feel they might be too big for the room (sound and appearance) Might sell or trade.
  • geppy1
    geppy1 Posts: 3,076
    edited January 2014
    I hve tried LS 90s several times with different units and postions The bass is very heavy and that pushes vocals to the back of the stage however sticking a towel in the ports helped. I do prefer the bass to the LSI15 whose bass sounds disconnected from the rest of the spectrum
