LFE or Normal
My old Sony receiver used LFE, so on the back of my Infinity sub I had it switched to LFE.
On my new Onkyo 601 receiver there is no setting that I can go into to change the LFE, so I don’t think that it uses LFE. I can go in and set the crossover.
I still have a single cable coming from the receiver and connected to the left input on the back of the infinity sub.
My questions are, I have the switch on the sub set to Normal now. Is that correct? Does the Onkyo use LFE and not label it? Is there a difference between setting the switch on the sub to Normal or LFE?
Thanks for any replys.
Post edited by johnny_utah on
