Is there a difference in HDMI cables?
1234689
    edited March 2013
    For the hell of it, I sent an e-mail to HDMI.org asking one of their engineers to chime in on this. I'm sure it'll get ignored... but I figured it would be interesting if they answered.
    .....and for some reason you think an engineer will know the differences in sound characteristics. Nasa employees a boat load of engineers, not one can tell you how the space shuttle handles but they can tell you how its suppose to handle on paper.
  • sodablue
    sodablue Posts: 24
    edited March 2013
    BlueFox wrote: »
    Ask Roger Russel. Apparently, he is some type of cable guru.
    Interesting article.... http://www.roger-russell.com/wire/wire.htm
    edited March 2013
    Wish I had a nickel for everytime someone posts that stupid article. No offense Sodablue, just that it's like seeing that ugly chick in HS everyday hanging out by your locker.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited March 2013
    tonyb wrote: »
    I think an engineer can explain how packetized data can't be altered by signal quality in the TMDS digital transmission system. It isn't like I'm asking about analog here. Not that I guess it will matter... because it isn't like I'm going to convince anyone, apparently. Still, humor me... They probably won't even answer.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
    edited March 2013
    Nobody was talking about altering the data transmission. We are talking sound characteristics within the same data stream. Unless of course you believe that sound and 1's and 0's are both the same thing.
  • headrott
    headrott Posts: 5,496
    edited March 2013
    Again, regardless if it's analog OR digital; ANY signal can be influenced electrically and dynamically. Analog can certainly be influenced MORE and that goes without saying. Digital can be influenced, but to a lesser degree. Have you listened for the electric and dynamic influences imposed upon DATA (digital signals) using a high resolution sound system?
  • headrott
    edited March 2013
    tonyb wrote: »
    Right Tony. The 1's and 0's are the digital encoding of the audio. Of course they are not directly the audio signal itself otherwise we wouldn't need a D/A converter. I do believe DATA can be electrically and dynamincally influenced causing the DATA to exhibit these influences when converted back to analog by the D/A converter. Of course, this is at a smaller scale than kuntasensei is looking (listening) at. Otherwise, he would hear the differences in DATA transmissions depending on digital cable quality.
  • mantis
    mantis Posts: 17,557
    edited March 2013
    Isn't each level of CAT datacable spec'd for such and such frequency? I believe 5e is 100Mhz. Then the twist per inch go up and with CAT6 there is a spline that keeps the twisted pair pushed a bit farther away. CAT 6 isn't going to give you anything over 5e on 10/100/1000 networks. Correct me if I am wrong but 100MHz is an order of magnitude greater then 20Khz?
    So is your house wired with CAT5 for running data or running analog?
    I had to run two 75 foot runs of shielded CAT6e for running HDMI to an outside TV and used Mono-price 24AWG HDMI cables and Mono-Price HDMI powered extenders. Cost about $100 and doing 1080P and the pic looks great.
    My House is completely wired in Cat5e cable for network use. I'm gonna upgrade that wiring to cat6 or 7 if I buy a spool of Audioquest. I know from experience with data cables , it's mostly in the termination where signal loss is found. In a home network non live data transfers , cat5e is fully capable of sending all 10/100/1000 data up to 330 feet no problem. Cat 6 can also do this with more bandwidth at the same length. Cat 7 is a new designed cable and I currently don't know it's spec as I have not used it or was trained on it.
    Live data transfer can fail from time to time and having the best possible cables in place is a good was to minimize loss. Cat cabling is not expensive and rewiring my house is a breeze. I have a full open 9 foot basement and my network lives down there.
    Dan
  • kuntasensei
    edited March 2013
    tonyb wrote: »
    But there are no "sound characteristics" within the data stream because there is no SOUND in the data stream. The same packet of data should be converted by the DAC exactly the same every time, given the same exact packet of data, hence LOSSLESS AUDIO. That's my point... The quality of the audio at that point is dependent upon the quality of the DAC. But changing from one cable to another can't affect the audio quality for the lossless formats because they are either receiving the same exact audio data or they're not, and the content of those data packets can not be affected by jitter by design - they either arrive intact or they don't. The only artifact that can possibly occur with packeted data will be dropouts, so if you aren't getting dropouts, you're getting the same data you would get from one cable to another, signal quality be damned.
    Same concept for video over HDMI. The circuitry at the display determines the quality at the panel, which is why you calibrate the display to known standards. But so long as the cable is not exhibiting any of the characteristics of low signal as previously stated, the packets of data are the same from one cable to another.
    That's why I think it will be interesting if they respond (though it still won't change anyone's minds that the 1s and 0s are somehow shinier, I suppose).
    Equipment list:
    Emotiva XPA-3 amp
  • kuntasensei
    edited March 2013
    headrott wrote: »
    I'm not disagreeing that signal can be influenced, nor am I disagreeing that digital data can be corrupted across a cable. But in the case of HDMI's transmission method, there is a mechanism in place for error checking and rejection that eliminates this issue.
    The 1s and 0s at the source device (say, the raw digital from a TrueHD track, for instance) are converted to 10-bit packets of data, similar to the way ZIP and RAR files on your computer are compressed versions of larger data. In this compression, there is an 8-bit word and 2 bits of checksum data so that the sink end (the AVR, the display, etc.) can ensure that the data packet arrived 100% intact. These 10-bit packets of data are what is sent over the HDMI cable. Then, at the receiving end, the HDMI chipset (which has a buffer so it may handle the error checking and conversion) converts these 10-bit words back to the raw digital data WITHOUT ANY CHANGES. If any of those data packets do not arrive intact, the HDMI chipset checks for the correct packet in the redundant data feed and if it finds it, it sends it on time with nary a hitch. If the quality of the cable, however, is such that these data errors occur regularly, the HDMI chipset at the receiving end runs out of buffer space and goes into blanking - the point where the display or AVR aren't being sent any data because the packets aren't arriving intact.
    Hence what I have said all along: If a low-quality cable is getting the packets there without the audio dropouts or video speckling/total loss that corrupted signal exhibit, a higher quality cable will have ZERO differences post-transmission because the data is exactly the same. The DAC at the AVR or the video chipset at the display don't even SEE the signal strength because they aren't fed signal. They're fed the data that the HDMI chipset converted back from 10-bit compressed and error-checked packets. Identical 1s and 0s = identical output... and if it doesn't, then there's some kinda' mystery going on at the sink, not the cable.
    (I know at this point I'm just talking to myself... because I'm not going to change anyone's mind, no matter how well I explain the mechanism. But hey, at least I made the effort.)
    Equipment list:
    Emotiva XPA-3 amp
  • Habanero Monk
    Habanero Monk Posts: 715
    edited March 2013
    Informative video to say the least. You can only get it in Canada I guess. Seen this one awhile ago. I'll search for a US link of it.
  • acmf74
    acmf74 Posts: 937
    edited March 2013
    Is the main difference between the Forest and Cinnamon the silver content in the Cinnamon?
    Thanks.
  • mantis
    edited March 2013
    acmf74 wrote: »
    Thanks.
    That is 100% correct.
    Dan
  • acmf74
    acmf74 Posts: 937
    edited March 2013
    This post has me very interested in trying out the AQ HDMI line.
    My question is if I were only to use the HDMI cable for VIDEO ONLY should I try out the Forest or go to the Cinnamon?
    I use a digital cable for my sound.
  • Habanero Monk
    edited June 2013
    It's not the Canadian Broadcast but one done by a U.S. news station:
  • headrott
    edited June 2013
    ^^^^^That was a terrible report^^^^^^. There was no proof (either way) presented when the HDMI cables were put on the "scope". They simply stated that they put them on a scope and compared them. They offered no results. What a waste of time. Also, it looked like the Blu-Ray player they were using to compare the HDMI cables was as expensive as the more expensive HDMI cable itself. I have no clue how good of a display they used. Of course you aren't going to notice a difference in HDMI cables if you are sending a video signal from a Blu-Ray player as expensive as your HDMI cable (approximately). Again, a waste of time and money. What were you trying to prove by this post? You'll have to post something that actually has proof in it or it's a waste of time. Again, the best proof is by doing a comparison for yourself........
    F1nut Posts: 51,917
    edited June 2013
    He's trying to prove that he has no personal experience and relies on others for the basis of his opinions. I'd say he did a damn fine job of proving his point.
    edited June 2013
    The cable itself doesn't alter the data stream obviously, it's the quality of the cable/materials used/design, that alter the final sound. Nobody is saying data is altered, just how much of that data is audible and the tonal qualities is the ticket.
  • Habanero Monk
    edited June 2013
    I'm saying you guys can't pick out a quality $20 cable from a quality $200 cable. Period.
    F1nut Posts: 51,917
    edited June 2013
    Actually, what you are saying is that I hit the nail on the head. Granted, you made it easy.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited June 2013
    I can tell with a longer run on my JVC, when I swapped out the wireworld silver starlight or even the Aurora the picture quality lessens. So I would have to say I am capable of picking out a good cable
  • Habanero Monk
    edited June 2013
    With any cable length beyond the actual spec agreed. For 6 foot runs which is the rule, not the exception, isn't going to happen. You would be guessing at best. Keep in mind I used $20 as the minimum for cable. I'm sure the bargain bin at ebay has something that is going to do a poor job.
    More time reading what is posted would help you guys. I'll be at MWAF it anyone wants to try it out. I'll bring a $20 and a $200 6ft cable. Loser buys the beer.
  • Habanero Monk
    edited June 2013
    How about Blue Jean Cable BJC Series-FE 6 ft vs ~ $200 6ft that anyone wants to bring?
  • chumlie
    chumlie Posts: 8,658
    edited June 2013
  • Habanero Monk
    edited June 2013
    chumlie wrote: »
    Whats MWAF ?
    Midwest Audio Fest put on by Parts Express outside of Dayton Ohio. It'll be attended by a bunch of people that also know a $200 6ft length of cable isn't going to outperform $20 of same.
  • headrott
    edited June 2013
    You mentioned what $20.00 cable, but failed to mention a $200.00 cable to compare it to? Just because a cable costs $200.00 doesn't mean it will outperform a $20.00 cable. Why not state a cable that uses well designed solid pure silver and/or PCOCC (copper wire) with excellent dialectrics and well designed, implimented and high quality material shielding and construction? That makes more sense than simply stating "a $20 cable vurses a $200 cable". You are trying to "bring down" a high quality cable to the level of a "cheap" cable. I define a "cheap" cable as one using low quality materials, design, and construction. I define "high quality" as mentioned above.
    Also, as I brought up before; what blu-ray player are you hooking these cables up to? In the video you posted, I would guess it was a $175.00 blu-ray player (at best). I cannot read the brand name on it, however (I would need a bigger screen than my laptop screen to read it). What display/projector/screen, etc. are you displaying and playing the blu-rays on? If you are doing a similar test as in the video you posted (i.e. using a $175 blu-ray player and hooking up a $20 and $100 HDMI cable to it to "compare", I would say you probably won't notice a difference in picture quality. This is because you are using a blu-ray player that is equivalently capable of displaying a better picture as the $20 cable. Of course you won't see a difference). That is, with lower quality design and parts (i.e. capacitors, resistors, rectifiers, etc.,etc,.ect.) used in the blu-ray player, you cannot put out a higher quality picture and sound.
    F1nut Posts: 51,917
    edited June 2013
    Nothing like making a prediction before you or the bunch of people you somehow think you speak for actually try different cables. Your bias is glaring and therefore your thoughts on the matter should be dismissed outright. What is also glaring is your lack of a response to the comment about your inexperience with other HDMI cables.
    Life can be tough when you bite off more than you can chew.
  • Habanero Monk
    edited June 2013
    headrott wrote: »
    headrott wrote: »
    I'm throwing this out there for anyone that would like to unequivocally demonstrate that $$ buys performance when it comes to some 6ft HDMI cables. That is why I am leaving the $200 brand open to what ever. It's just beer.
    headrott wrote: »
    I will bring a computer with two identical ATI Radeon's and a display device with multiple HDMI inputs. The displays will be mirrored in Windows and the participant can A/B with remote between cables. This will be single blind as I will know which display is which but not participating.
    headrott wrote: »
    ATI Radeon's are without reproach when it comes to Picture Quality.
  • Habanero Monk
    edited June 2013
    You are always welcome to attend and have a blast and let me buy you a few beers. Chew on that.
  • headrott
    edited June 2013
    Let me just sum up your post by saying you obviously didn't comprehend and/or are ignoring what I stated in my past couple posts. You are not going to see a difference in HDMI cables using a computer (with a low quality (low quality again defined as lower quality capacitors, resistors, transport mechanism, laser, etc., etc.) blu-ray player in it compared to say even a Denon DVD-A1UDCI let alone an even better player) as a source for displaying your picture.
    ATI Radeon's might be without reporach when it comes to displaying picture quality.........in computers. One problem with stating that ATI Radeon's are without reproach in picture quality is partly that you are only looking at one single aspect of the entire system. That is, you are looking only at the video processing (in the ATI Radeon card). What about the transport mechanism? What about the capacitors, resistors, bridge rectifiers, etc., etc., etc., what about the quality of laser used to read the blu-ray that are involved in making the data signal being sent through the HDMI cable and then converted by the display? (ie. projector, LED tv, plasma tv, LCD tv). But my argument would be that a stand alone high quality blu-ray player will absolutely outperform your computer based "blu-ray player". This is because the quality of parts used in a stand alone player such as the Denon DVD-A1UDCI (although there are even better examples) are much better than your computer based blu-ray player. You problem with comparing HDMI cables is you aren't looking at the "full picture" (yes pun intended) of everything that goes into displaying the picture you see and the audio you hear. That is, you are not looking at a fine enough scale and not a broad enough view when it comes to displaying picture quality differences in HDMI cables.
    Also, I think you should participate in the comparison after you actually assemble a video system that is actually capable of displaying the differences in higher quality and lower quality HDMI cables; because the system you spoke of above will not do it (just as it did not do it in the video you posted).
