Trying to figure out the best center speaker to go with. So confused! help
Okay so just got a new 7.1 surround sound receiver. I have 2 klipsch towers for my fronts and a psw10 polk subwoofer. I am wanting to get a polk center speaker. I have been looking at the cs10, cs 20 and the cs2. I have the room to put it as I have read they are big. Just wondering which is the best one to go with. I will be getting some rear surround polkas to. Any suggestions on that would be great. I am on somewhat of a budget also. Any help appreciated. Thanks
First off, why do you want a Polk center to go with Klipsch towers? That won't even come close to timbre matching.My humble setup...
...is no more.
Get a Klipsch Center to match the fronts. That is normally recommended. Which Klipsch mains do you have?
I think adding a center channel could hurt your soundstage....
Higher number of speakers doesn't mean it's automatically better.
cheezy -
Okay the fronts are klipsch kg45. I mainly want a nice sounding surround for playing movies. I do not listen to music that often. So main focus is movies. I wanted polks as the reviews on them have been awesome. What your saying is I should match them up with klipsch center and surround rears? So your saying buying a polk center will not help my system sound better? I should get a klipsch?
Get any Klipsch center.
You can get KV-1 for cheap used.
Polk center won't match with Klipsch's horn sound.
Thank You!
Or, if you're really after the Polk sound, sell your Klipsch's and buy Polk fronts and a Polk center.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Good thought.falconcry72 wrote: »Or, if you're really after the Polk sound, sell your Klipsch's and buy Polk fronts and a Polk center.
Also, those KG45 do bring decent price but if you like horns, it's hard to beat Klipsch's.
For those who find horns too bright, Polks are great.
I think a polk center with the tri-laminate tweeter would do a closer match to the kg5 , even though its not a horn the trilaminate has a more localized sound then the silvercoil or cloth soft domes ( just my opinion )Get any Klipsch center.
Polk center won't match with Klipsch's horn sound. -
Tri lams sound nothing like Klipsch horns IMO. Decide which way you want to go and buy accordingly. -
agree go with the klipsch center, it will match up better than the polk
+1, you should stick with the same brand, in order to maximize smooth transition between speakers!SRT Seismic System with dual PSW1200's
RT5000 x 2
RT2000p
CS400i
CS350-LS
LS F/X
PSW650
PSW1000 w/Dayton SPA1000
DSW MicroPro 4000
Adcom amps
Pioneer Elite SC-89
Pioneer PLX-1000 Turntable
PS4
XBOX One
MIT Interconnects
BJC
