Best Wireless Router with Parental Controls
Conradicles
Conradicles Posts: 6,342
edited January 2014 in Electronics
Our NetGear WNDR3400 is starting to kick the bucket. We had Geek Squad come out and look at it and they confirmed all is setup correctly.
Can we get some recommendations from you computer experts out there on a new router that has parental controls and pumps out a strong signal.
Price wise we would like to stay under $150.
Let me know if more information is needed.
Thanks!
Eric.
Post edited by Conradicles on
  • jbooker82
    jbooker82 Posts: 1,627
    edited March 2013
    I have been running an Asus 900 meg dual band wireless router for about 4 months now. I have not had to restart it once. I get my full internet speed over wireless. It is a pretty heavy weight for a router. It has built in heat sinks, and a good amount of memory wich keeps conection speeds up when you have a buch of wireless devices connected. It has a nice grafic userer interface too.
    It is at the top of your budget. I would deffinatly buy this router again.
    Here is the link
    http://www.newegg.com/Product/Product.aspx?Item=N82E16833320091
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    tonyb Posts: 33,072
    edited March 2013
    Best parental controls ? It's called the on/off switch.
    Tell us what exactly you use the router for and whats hooked up to it.
  • Conradicles
    edited March 2013
    Thanks jbooker82 that looks like an option. Would you say setup is user friendly?
  • jbooker82
    edited March 2013
    Yea I would say it is very user friendly. It has a real nice user interface. It is about like opening up the control panel on your computer. You don't have to scroll through menus to try to find what your looking for. There are links to video tutorials that show you how to adjust stuff.
    There is a parental control menu that allows you to assign times when each devices can connect to the network.
    Here is the one for the Parental control part.
    http://www.youtube.com/watch?feature=player_embedded&v=IbsuvSjG0xM
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • Conradicles
    edited March 2013
    Thanks a bunch. Obviously you can block adult content as well. I will do some reading up on that model.
  • jbooker82
    edited March 2013
    Here they do a real world test.
    http://www.youtube.com/watch?v=pKevpqBqUU0
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • jbooker82
    edited March 2013
    It has a place where you can put specific URL's to block and it can also block what ever key words that you would like. I couldn't tell you how well that part works because I don't have it enabled.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • chiptouz
    chiptouz Posts: 152
    edited March 2013
    For me net gear and Linksys are the best. Most parental controls are available in windows once you create a separate profile.
    Sharp LC-80uq17u
    Denon 4520ci Receiver
    OPPO BDP-203 Blu-Ray Disc Player
    Monster HTS 3600
    Polk RTi-a7 (fronts)
    Polk CSi-a6 (Center)
    Polk TC-60i (Rear & Surround Rear)
    HSU Research VTF3-MK4 (Sub)
    Logitech Harmony elite (Remote)
  • skrol
    skrol Posts: 3,449
    edited March 2013
    Check out the iBoss. The parental controls are excellent. My only issue is, though minor, is that the wireless is not dual band.
    http://www.iboss.com/
    I got mine here:
    http://www.familysafemedia.com/iboss_internet_parental_contro.html
    My kids hate it when they try to get around it, so I know it is doing its job.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Sherardp
    Sherardp Posts: 8,038
    edited March 2013
    Asus RTN66U is the best you can get for a good price. There is one other Asus model above it, but the 66U aka the Dark Knight has amazing range and speed.
  • jbooker82
    edited March 2013
    Sherardp wrote: »
    I am 100% happy with mine, and would buy it again.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • zingo
    zingo Posts: 11,258
    edited March 2013
    You want to do parental controls at the DNS level: http://www.opendns.com/home-solutions/
  • PrazVT
    PrazVT Posts: 1,607
    edited March 2013
    Sherardp wrote: »
    I have the RT-AC66U model - indeed, it's pretty speedy.
    Otherwise, I think a couple of older / but reliable models I've used are: Netgear WNDR3700 and D-Link DIR-655. I actually just replaced a Netgear R6300 (similar performance to the Asus), because the R6300's wireless LAN transfer speeds were horrible. Not sure if I got a dud, but had some bad luck with that one.
    Much more customization available w/ the Asus routers.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • cc43fan
    cc43fan Posts: 22
    edited March 2013
    Google "Cisco outlet". Use can buy their really nice gear for much less than new, and it comes with the same warranty as new. Use can configure the router to times of day it can be used, block sites (although you'd be better off using parental controls on the computer).
  • Conradicles
    edited January 2014
    Finally got around to upgrading our wifi router.
    Much thanks to jbooker82, Sherardp, PrazVT for recommending the Asus RTN66U. Set-up was a breeze and it works fantastic.
  • j1mmy
    j1mmy Posts: 95
    edited January 2014
    +1 for the asus
