SPL meter
marcpam
marcpam Posts: 228
I'm just curious, how many of you use a SPL meter to fine tune your home theatre system? I know that this may be a personal preference issue, but I am thinking about doing it.
Post edited by marcpam on
  • gatemplin
    gatemplin Posts: 1,595
    edited June 2004
    I found that the Sound and Vision Test disc, and SPL meter helped a lot. I was running my sub about 13 dB hot, now it is just 2-3 hot. I really had no idea before. I also use the SPL meter frequently when making changes to my parametric eq. Also the speakers sound much better when they are all properly balanced.
    Graham
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2004
    I'd say using it is a good idea becuase it can detect minor differences that your ear cannot.
    That being said, I don't own one but plan on picking one up soon.
  • Willow
    Willow Posts: 11,339
    edited June 2004
    if they we not so darn expensive here in canada....89$ cad....I thougt of buying one but always fine something esle to buy( for the house :mad: one day.....one day.....
  • wrxmy02
    wrxmy02 Posts: 92
    edited June 2004
    Was lucky enough to get the older Radio shack one with the neddle. I used the S+V test CD tones.
    Well worth it...balanced my center very well with the L+R.
    Thought it was pretty steep to pay $60 for such little use but after setting up a few freinds systems [mount it on a tripod..more beer looks better] it din't set idle long.
    Front: LSI7
    Center: LSIC
    Surrounds: LSI7
    SVS PB2-ISD SUB [MONOLITH!]
    ATI 1805 Amp
  • Lee Bailey
    Lee Bailey Posts: 71
    edited June 2004
    I've been using one for years, even before HT.
    Please feel free to visit my Home Theater Page at The Bailey's Home Theatre in our Living Room.
  • brody05
    brody05 Posts: 329
    edited June 2004
    I have one, but to be honest the only thing I use it for is getting close to the 'ideal' equal level, then I play around slightly until it sounds 'right' to me, recheck with the SPL and sometimes find things a bit out, but hey, if it sounds good to me.....
