Tower surrounds?
ScottyDugs
ScottyDugs Posts: 91
edited March 2013 in Speakers
Is it a bad idea to have towers up front and towers as rear surround also? Example, matching LS90's for my setup
My SETUP
AVR: Denon 1913
Main L/R: Polk LS90's
Center: Polk CS350LS
Side Surrounds: Polk LS/FX's
Rear Surrounds: Polk RT/FX's
Subwoofer: Polk PSW300
100% Cinematic Adventures, 0% Music
  • Mystery
    Mystery Posts: 2,546
    edited March 2013
    No, it's not a bad idea. It's a very good idea.
    I have 42" tall towers as my side surrounds and it sounds NICE.
  • ken brydson
    ken brydson Posts: 9,098
    edited March 2013
    I'm running 90's as mains, LS/fx's on the sides and LS50's in the rear. It sounds awesome!!
  • ScottyDugs
    edited March 2013
    Nice. Does it play louder in the rear like that compared to smaller rears?
    My SETUP
    AVR: Denon 1913
  • Mystery
    edited March 2013
    ScottyDugs wrote: »
    That depends upon efficiency of the speakers.
    Also, you can control volume levels to side/rear surrounds in the receiver.
  • ken brydson
    edited March 2013
    It doesn't play louder but I think it is has a much fuller sound with the larger speakers.
  • ScottyDugs
    edited March 2013
    Ok good
    My SETUP
    AVR: Denon 1913
  • falconcry72
    falconcry72 Posts: 3,580
    edited March 2013
    ScottyDugs wrote: »
    No, use your receiver to set the volume.
    Towers will definitely have better bass than smaller surrounds, but almost no bass ever gets sent to surrounds anyway. I would prefer dipoles or bipoles to towers because they create a more dispersed, enveloping sound. Plus you have more placement options with smaller surrounds (above ear level).
    Try messing around with the settings in your receiver before you go buying towers for the sides. I think you might just need to increase the channel level to your surrounds.
  • ScottyDugs
    edited March 2013
    Yea I just thought it be nice to have more bass in the back(for the times bass does get sent to the back) but im fine with smaller ones for now...is it good to place rear and side surrounds above ear level?
    My SETUP
    AVR: Denon 1913
