Dynamic Volume Compression?
ScottyDugs
Should dynamic volume compression for audyssey be set to off,heavy,medium, or light?
My SETUP
AVR: Denon 1913
Main L/R: Polk LS90's
Center: Polk CS350LS
Side Surrounds: Polk LS/FX's
Rear Surrounds: Polk RT/FX's
Subwoofer: Polk PSW300
100% Cinematic Adventures, 0% Music
AVR: Denon 1913
Kind of a personal preference I guess, I usually leave it off for movies but it can keep commercials from blowing your ear drums. It can also limit the range in a movie if you feel like you have to turn it up loud to hear to vocals but explosions etc. are too loud, saves you from reaching for the remote the entire movie.
So by volume compression do they mean lossy? Does it take away from lossless audio or is that a different compression?My SETUP
AVR: Denon 1913
100% Cinematic Adventures, 0% Music -
It's not changing the format or losing anything, it's just taming the volume spikes and bringing up the lowes to a more even level. Think of a movie where a quiet conversation is taking place followed by a loud action scene. If you're having trouble hearing the dialogue and then all of a sudden the action scene is so loud you have to turn it down, it keeps everything on a more constant level.
Here's a link that can explain it a little better: http://www.audyssey.com/audio-technology/dynamic-volume -
I keep mine set to "off", but I don't have crying babies or angry neighbors to worry about!Front Speakers: Polk Audio LSi15 x 2
Center Speaker: Polk Audio LSiC
Rear Speakers: Polk Audio LSiF/X x 2
Subwoofers: Polk Audio PSW505 x 2
AVR: Denon AVR-3313CI
Amp: Emotiva XPA-5 -
Yea me neither...i seem to like it on set to medium because i tried turning it off and loud noises were scaring me hahaMy SETUP
AVR: Denon 1913
well at least the sudden difference from soft to loud was freakin me out i mean...its like getting slapped in the back of the head and u dont know its coming...hate thatMy SETUP
AVR: Denon 1913
I like dynamics in audio, so I leave it off. I will only use it at night when others are asleep so I can keep the overall volume level lower.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
Off because I like to hear the movie they way the sound engineers intended it to be heard. Plus I try to limit unnecessary processing as much as possible.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
falconcry72 wrote: »Off because I like to hear the movie they way the sound engineers intended it to be heard. Plus I try to limit unnecessary processing as much as possible.
Why is everything louder while using dynamic volume compression? I had my volume down to 20 and I could barely hear anything while the dynamic volume was set to off...but when I turn the dynamic volume to light it is louder. I would think that dynamic volume set to off would be louder, no?My SETUP
AVR: Denon 1913
ScottyDugs wrote: »Why is everything louder while using dynamic volume compression? I had my volume down to 20 and I could barely hear anything while the dynamic volume was set to off...but when I turn the dynamic volume to light it is louder. I would think that dynamic volume set to off would be louder, no?
In theory, with dynamic volume OFF, quiet sections should be quieter, and loud sections should be louder. Every receiver is different though, so how your receivers does it may vary from a different company.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
When it is off, the signal is unprocessed and the result is loud parts are loud and quiet parts are quiet. When it is on, the DSP brings the lows up and the highs down, making for a sound that is less dynamic; hence the name. However, the process in which the high and low dynamics are compressed my result in a final sound that is nominally louder than the unprocessed signal. -
Ok now it makes sense. Thanks dudesMy SETUP
AVR: Denon 1913
