Subwoofer Speaker Ports?
ScottyDugs
Why does it look like I can plug 4 speakers into the back of my subwoofer (labeled speaker level inputs)? Isnt that what the avr is for or is this something completely different?
My SETUP
AVR: Denon 1913
Main L/R: Polk LS90's
Center: Polk CS350LS
Side Surrounds: Polk LS/FX's
Rear Surrounds: Polk RT/FX's
Subwoofer: Polk PSW300
100% Cinematic Adventures, 0% Music
AVR: Denon 1913
ScottyDugs wrote: »Why does it look like I can plug 4 speakers into the back of my subwoofer (labeled speaker level inputs)? Isnt that what the avr is for or is this something completely different?
Pictures help -
My SETUP
AVR: Denon 1913
100% Cinematic Adventures, 0% Music -
The top set is an input and the bottom set is an output. You could run your speaker wires from the amp/receiver in to the sub and then out to the speakers. I am not familiar with this model but most subwoofers would have a high-pass crossover out to your speakers. Most people use the line level inputs.
Some companies like REL recommend that you use the speaker/high level input so the sub sees the exact same signal as your speakers for better integration. -
Ok so here is my avr...which cables would go where to the sub?
My SETUP
AVR: Denon 1913
See that jack on the lower left of the AVR, the one that says subwoofer? Run a sub cable from there to either the L or R line level input on the sub.
My humble setup...
...is no more.
ha i know but im asking about hooking up to the speaker level inputs and outputsMy SETUP
AVR: Denon 1913
if you use this method, make sure set speakers to Full Range or Large on your AVR
It is made available if u are using an amp with no subwoofer out. U would run your wire from your amp left and right to your sub then from the sub to your speakers. Thats my understanding of it anyhow...
ok thanks...so it wont make anything better compared to regular sub out cable?My SETUP
AVR: Denon 1913
it's that one is better than another, just different way to get bass out of your sub. With the Sub cable, your AVR sums the bass from L/R and sends to the sub. With the speaker level setup, your sub is doing the summing from L/R from the AVR. Same result.
If your receiver has a highpass crossover for your mains it is probably best to use the subwoofer out jack so you can cut the bass going to your mains.
What speakers are you using? -
Polk LS90 standing main speakersMy SETUP
AVR: Denon 1913
I would use the subwoofer preout to the sub.
If you have a high pass feature on your receiver I would recommend using it to your fronts to lessen the burden of your receiver. -
comes down to ( what sounds best ) if your sub is able to reproduce the lows better than the mains you need to switch the high pass ( sub on option ) if you dont some of the bass goes to mains and sub sounds worse .
I have found getting lows to the sub ( thats is designed job ) will sound best .
