Subwoofer Speaker Ports?
edited March 2013 in Speakers
Why does it look like I can plug 4 speakers into the back of my subwoofer (labeled speaker level inputs)? Isnt that what the avr is for or is this something completely different?
My SETUP
AVR: Denon 1913
Main L/R: Polk LS90's
Center: Polk CS350LS
Side Surrounds: Polk LS/FX's
Rear Surrounds: Polk RT/FX's
Subwoofer: Polk PSW300
100% Cinematic Adventures, 0% Music
Post edited by ScottyDugs on
Welcome!
    edited March 2013
    ScottyDugs wrote: »
    Pictures help
    edited March 2013
    My SETUP
    AVR: Denon 1913
    edited March 2013
    The top set is an input and the bottom set is an output. You could run your speaker wires from the amp/receiver in to the sub and then out to the speakers. I am not familiar with this model but most subwoofers would have a high-pass crossover out to your speakers. Most people use the line level inputs.
    Some companies like REL recommend that you use the speaker/high level input so the sub sees the exact same signal as your speakers for better integration.
    edited March 2013
    Ok so here is my avr...which cables would go where to the sub?
    My SETUP
    AVR: Denon 1913
    edited March 2013
    See that jack on the lower left of the AVR, the one that says subwoofer? Run a sub cable from there to either the L or R line level input on the sub.:lol:
    My humble setup...
    ...is no more. :cry:
    edited March 2013
    ha i know but im asking about hooking up to the speaker level inputs and outputs
    My SETUP
    AVR: Denon 1913
    edited March 2013
    if you use this method, make sure set speakers to Full Range or Large on your AVR
    edited March 2013
    It is made available if u are using an amp with no subwoofer out. U would run your wire from your amp left and right to your sub then from the sub to your speakers. Thats my understanding of it anyhow...
    edited March 2013
    ok thanks...so it wont make anything better compared to regular sub out cable?
    My SETUP
    AVR: Denon 1913
    edited March 2013
    it's that one is better than another, just different way to get bass out of your sub. With the Sub cable, your AVR sums the bass from L/R and sends to the sub. With the speaker level setup, your sub is doing the summing from L/R from the AVR. Same result.
    edited March 2013
    If your receiver has a highpass crossover for your mains it is probably best to use the subwoofer out jack so you can cut the bass going to your mains.
    What speakers are you using?
    edited March 2013
    Polk LS90 standing main speakers
    My SETUP
    AVR: Denon 1913
    edited March 2013
    I would use the subwoofer preout to the sub.
    If you have a high pass feature on your receiver I would recommend using it to your fronts to lessen the burden of your receiver.
    edited March 2013
    comes down to ( what sounds best ) if your sub is able to reproduce the lows better than the mains you need to switch the high pass ( sub on option ) if you dont some of the bass goes to mains and sub sounds worse .
    I have found getting lows to the sub ( thats is designed job ) will sound best .
Welcome!
Welcome!
