Need suggestions for side side speakers
l80241
l80241 Posts: 23
edited March 2013 in Speakers
I'm hoping you all might have an idea of what surround speakers would be a good fit for my setup. I just finished the basement and am out of funds and will be for quite a while. My wife has been a good sport but I'm being cut off, financially.
This is what I've been able to cobble together so far for sound:
Center - Lsic
Fronts - Lsi7
Sub - HSU VF-2
Recvr - Denon 3312
Amp - 1 Emotiva upa1 for the center
The Lsifx are hard to come by, are more $$ than I can spend now, are harder to drive and might require an additional amp, are big. So, I'm looking for other options for surround speakers even though I know it's not optimal. Budget is $200 - $400
I googled but didn't find many suggestions. Oh, and the back of the room is open to the rec area so I'm looking atside speakers unless I go in ceiling. I'm considering
Polk FXi A4 -
Polk 80 ls/fx - in ceiling is not my first choice but cold work
Magnepan – mmgw $325 - 4 Ohm - hard to drive
Mirage Omnistat - not sure of the models
ANy ideas on how any of these would match up, would perform as side speakers? Any and all suggestions welcome.
  • monepolk
    monepolk Posts: 1,154
    edited March 2013
    Why not another pair of the LSi7s?
  • codyc1ark
    codyc1ark Posts: 2,539
    edited March 2013
    I'd go for the 7's if you can swing them and have the room to mount or put on stands properly.. If you can't I run an LSi setup and use the Mirage OMD-5's (I think) for surrounds, blends very well and sounds good. Good luck!
  • l80241
    l80241 Posts: 23
    edited March 2013
    I don't think I have enough space on the sides to accomodate the 7's and if I put them behind the seating they'd have to be on the counter/bar and only 2 feet or so from my head. Plus I'd like to try something more diffuse.
    Cody, can you give me any more insight on the OMD-5's performance. I'll definitely give them a look.
  • rpf65
    rpf65 Posts: 2,127
    edited March 2013
    Why not look at the FXI A 4 or 6. I know they are from a different, but think they still be a viable choice. Timbre matching, from what I understand, is more criticle for the front stage. I think that given the pricing difference between the LSI series and FXI series, it may be worth a look, or listen.
  • l80241
    l80241 Posts: 23
    edited March 2013
    rpf65, you bring up a good point. They are 8 ohms, so easier to drive, cheaper and smaller footprint than the Lsifx speakers. Don'tknow if anyone around here carries them though Best Buy carries them online.
  • rpf65
    rpf65 Posts: 2,127
    edited March 2013
    Amazon has FXI A6 on sale for $420.
