any suggestions on tower speakers
1niteryder
1niteryder Posts: 10
edited March 2013 in Speakers
I would like to get some tower style speakers for my system. Any suggestions on what to get or what not to get?
  • zane77
    zane77 Posts: 1,696
    edited March 2013
    What are you using these for, music, home theater, and what's your budget?
    Two Channel
  • RamZet
    RamZet Posts: 792
    edited March 2013
    I did a martinlogan setup for my sister, I am very impressed with them.
    We used the Motion 10's. They are very powerful and crystal clear ( due to that ribbon tweeter). They sounds great in both HT and 2ch audio. We were able to get them onsale at newegg for $99 each! (marked down from 600 each).
    I found them at amazon for $199 each. Great deal, Great buy, awesome speaker. They aren't very big, maybe 3 feet tall.
    http://www.amazon.com/MartinLogan-Motion-10-Floorstanding-Speaker/dp/B0035FZ142/ref=sr_1_1?ie=UTF8&qid=1362925183&sr=8-1&keywords=martinlogan+motion+10
    If you want something bigger they next step up is a motion 12 or motion 20.
    http://www.amazon.com/MartinLogan-Motion-12-Floorstanding-Speaker/dp/B0035FZ14M/ref=sr_1_1?s=electronics&ie=UTF8&qid=1362925519&sr=1-1&keywords=motion+12
    http://www.amazon.com/MartinLogan-Motion-Gloss-Black-Floorstanding/dp/B007THXXXS/ref=sr_1_1?s=electronics&ie=UTF8&qid=1362925572&sr=1-1&keywords=motion+20
    I did toss in a small polk sub for bass. If they had more or a budget I would have tossed in 1 or 2 B&W ASW608.
    Cool thing about ML is that BestBuy has them in Magnolia, so you can go hear them yourself. They are very directional speakers so make sure they are aiming near you to get the most out of them.
    Good luck, hope this helped.
    B&W CM9Classé Sigma
  • Irrenhaus
    Irrenhaus Posts: 1,105
    edited March 2013
    1niteryder wrote: »
    Dont know were you are located. But Frys has the RTi8 for $334.00 a pair this week.
    Cheers
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • vinyladdict
    vinyladdict Posts: 32
    edited March 2013
    Newegg has some Monitor 75T's for $219 a piece . Anxiously awaiting their arrival .
  • zingo
    zingo Posts: 11,258
    edited March 2013
    I love my pair of Martin Logan Purity powered speakers.
  • David R
    David R Posts: 134
    edited March 2013
    I picked up some RTi8's at Fri's for $300 the pair. They sounded great for home theater. My wife didn't like they way they looked so I sold them to my brother along with the Onkyo 609 at 100 wats per channel and a CSi center. They played louder than I could stand. I then picked up the RTIa7 with the Onkyo 809. Both speakers are fine for the price for home theater.
    Panasonic 65" Plasma - Panasonic Blu-ray. Onkyo TX-NR809 RTi A7s fronts - MK CS150s surronds.
    edited March 2013
    1niteryder wrote: »
    JM labs Grand Utopia, Legacy Whisper HD, Wilson Sophia, PBN Montana Was or Kas.....dude.....without a budget or associated gear to drive said towers, the results here will be all over the map.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited March 2013
    Since you're at Polk's forum, there's always the Polk eBay store: http://stores.ebay.com/Polk-Audio-Direct?_trksid=p2047675.l2563
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • halo71
    halo71 Posts: 4,642
    edited March 2013
    Hard to go wrong with SDA's. But not knowing budget or listening tastes....yeah, crap shoot.
    --Gary--
  • Monster Jam
    Monster Jam Posts: 919
    edited March 2013
  • Irrenhaus
    edited March 2013
    Wow yeah those are Bad **** and they come with special delivery.......
    :lol:
  • skrol
    skrol Posts: 3,490
    edited March 2013
    I found one of these at the local GW (Digital Research PT-1100)
    http://www.ebay.com/itm/Digital-Research-Speakers-/150989135459?pt=Speakers_Subwoofers&hash=item2327a75e63&nma=true&si=i4by36n2cGyJiS6QFFRGs4CqnKI%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
    Obviously not affiliated
    I like how they show the back and not much of the front.
    The cabinets were so thin that it felt like you could pop a hole with a good whack.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • 1niteryder
    edited March 2013
    These are for my home surround system. It is used for both music and home theater. Under $500.
  • 1niteryder
    edited March 2013
    thanks I will check them out.
  • 1niteryder
    edited March 2013
    I will go check them out tomorrow. Thanks.
